Code 3364 and 3521 came on my truck out the blue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DAX_, Sep 26, 2021.
  1. DAX_
    DAX_ Medium Load Member
    603
    504
    Sep 4, 2017
    Filled up def at flying j in Dallas on Thursday
    Today(Sunday) I fill up on diesel again at pilot in Decatur Illinois
    About 30 minutes later I see my check engine light is on(not flashing on solid) and my low def warning light is on
    I look on the dash and that fault code number (3364) comes on, saying exactly 'After treatment diesel exhaust fluid quality - abnormal rate of change '
    Then as I'm typing this thread fault code 3521 comes on saying "conditions exist"
    I'm running heavy, 45,000 pounds and have a 2020 freightliner so there is no regen button or regen override for me to press. The only thing I have is the regen I can click from the dashboard screen but that does not work
    Any help
  3. Daytrck
    Daytrck Bobtail Member
    Sep 26, 2021
    I’m new to trucking. I had a similar DEF problem totally different truck but I hear def problems run similar in most cases. I spent over $3000 looking for the issue and found out that it was just the filter pad at the bottom of the tank had gone bad and was clogging the lines. Try checking under the truck if it’s possible where the DEF is injected sometimes you can take that apart and wash it with a bit of water if it’s crusted or clogged to clear it and can keep you going for a bit or until it gets clogged again.
    If it persist you may want to drain the tank and see if there is any debris in the tank. I’ve heard from most mechanics that getting DEF from the pump isn’t good because you can sometimes pick up a lot of debris and transfer them to your tank. It’s better to buy the box knowing that what you’re pouring in is pure and clear.
    DAX_ Thanks this.
  4. DAX_
    603
    504
    Sep 4, 2017
    Update
    So last night as I get to the receiver my low def light starts flashing and I get a message that truck will now begin to derate at 5mph
    However the truck never derated at all.
    I make it to a mechanic but right before I get there all the lights and messages on the dash go away except for one which is the ECM 3521 saying DEF Fluid Property Conditions Exist
    The guys at the shop hook it up to a little computer and he tells me all the fault codes are inactive and that it won't shut me down.
    He also says that since everything is inactive they more than likely won't find anything wrong with it if they start working on
    Should I keep driving or take it to another shop
  5. dunchues
    dunchues Medium Load Member
    555
    960
    Mar 23, 2012
    new brunswick
    From my experiences it's probably not a real problem but more than likely a bad harness or weakening connection that's fooling the ecm. It can still lead to engine management taking over but if the condition isn't active they can't diagnose the fault. I'd wait till it lights up again ( and I bet it will ) before you throw parts at it that are likely ok.
    DAX_ Thanks this.
  6. DAX_
    603
    504
    Sep 4, 2017
    Would a freightliner dealer be able to diagnose it even without the lights being on?
    What if I take a pictures of the codes on the dash and show them
  7. dunchues
    555
    960
    Mar 23, 2012
    new brunswick
    They'll be able to see the inactive codes but there's no path to diagnose the problem, code has to be active so they can follow the steps to find the right fix.
  8. Diesel Dave
    9,230
    29,461
    Jan 20, 2010
    Hesperia, Ca.
    It’s a 2020, don’t you have a Warranty on it still ?
  9. DAX_
    603
    504
    Sep 4, 2017
    Yes
  10. DAX_
    603
    504
    Sep 4, 2017
    So do I just keep driving until im stranded lol
  11. dunchues
    555
    960
    Mar 23, 2012
    new brunswick
    If the codes aren't active you can't get to the root of the problem and all you can do is throw parts. Don't shoot the messenger, I don't care what you do I'm just explaining if the lights aren't on you can't properly fix it.
