Code 3577
Discussion in 'Ask An Owner Operator' started by Ikamob01, Apr 4, 2022.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    Reason:
    High signal voltage detected at the aftertreatment diesel exhaust fluid return valve.
    Fault Code: 3577 PID(P), SID(S): SPN: 4376 FMI: 3/3
    Lamp: Amber SRT:
    what could this be? Any help I will appreciate it.
    Cummins isx engine.
    D.Tibbitt Thanks this.
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    That sounds like the code for whip out $15,000 and get in line at the dealer. Boy I sure wish I had new trucks.
  4. D.Tibbitt
    148,960
    sounds like a bad def doser valve . .. pretty easy fix . coolant and def lines and a couple bolts. take off passanger side fairing/step to access it....
    @Goodysnap thoughts?
  5. Ikamob01
    314
    195
    Dec 4, 2021
    will check it out tomorrow. needs more help as much as i can get. But thanks tho.
  6. D.Tibbitt
    148,960
    First thing to check with anything emissions related, is the wiring harness and connector/plugs. Make sure no corrosion in plugs and no damage to wiring
    shooter19802003 and Ikamob01 Thank this.
  7. Goodysnap
    Goodysnap Road Train Member
    3,718
    9,033
    Jul 12, 2017
    Engine serial number?
    YMM of truck?
    Without looking it up. The return valve is in the dosing unit/DEF pump. Remove the connector from the pump and check for DEF leaking into the electrical connector. Or you have a wiring issue between the pump and ECM.
  8. Ikamob01
    314
    195
    Dec 4, 2021
    2015 prostate.
    Vampire Thanks this.
  9. Goodysnap
    3,718
    9,033
    Jul 12, 2017
    I think you need a doctor for that…..
    I won’t be much help. Lol
    shooter19802003 and loudtom Thank this.
  10. Ikamob01
    314
    195
    Dec 4, 2021
    you got it right. The return valve was replaced. kinda expensive tho.$900 for part 300$ labor.
    Vampire, Goodysnap and D.Tibbitt Thank this.
  11. D.Tibbitt
    148,960
    if you think thats bad wait until you need a new dpf or egr cooler.
    Brettj3876 and Vampire Thank this.
