code 95 help?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 05379, Aug 24, 2010.
  1. 05379
    05379 Light Load Member
    115
    Nov 15, 2008
    montague ma
    i got a code 95 today looked it up say's intake valve actuation oil pressure voltage fault has this happened to any of you if so what was the fix thanks any help would be great.
  3. DDS
    DDS Medium Load Member
    519
    177
    May 20, 2008
    Toronto
    Most common is the sensor is failing, Cat had problems with this pressure sensor. I have replaced many. If you have a BXS or early MXS you will have to update the connector at the sensor also.
    Table 1Engine Service Replacement for Pressure Sensor (VVA) C11 (S/N: KCA1-06123)
    C13 (S/N: KCB1-39998) 224-4535 Pressure Sensor Group C11 (S/N: KCA06124-UP)
    C13 (S/N: KCB39999-UP) 284-2728 Pressure Sensor Group C15 (S/N: BXS1-UP)
    C15 (S/N: MXS1-25316) 284-2728 Pressure Sensor Group
    249-5293 Sensor Harness Assembly [SIZE=-1](1)[/SIZE] C15 (S/N: MXS25317-UP) 284-2728 Pressure Sensor Group
  4. 05379
    115
    Nov 15, 2008
    montague ma
    thanks dds your the man i'll replace the sensor.
  5. 05379
    115
    Nov 15, 2008
    montague ma
    :biggrin_25514:i replaced the sensor and it fixed my problem thanks dds
