Code 95
Discussion in 'Kenworth Forum' started by 325TahoeSS, Apr 2, 2014.
  1. 325TahoeSS
    325TahoeSS Light Load Member
    150
    71
    Feb 11, 2012
    Roma, Tx
    I'm getting a code 95 on the dash of my 06, w900l, cat engine c-15!
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    That is an IVA code, (intake valve actuator) if the engine has NOT derated then it will be the IVA oil pressure sensor. This is located at the front of the engine on the head, right side. When you replace it make sure to get a new o-ring with it.
  4. 325TahoeSS
    150
    71
    Feb 11, 2012
    Roma, Tx
    What do you mean "if the engine hasn't derated?"
  5. 325TahoeSS
    150
    71
    Feb 11, 2012
    Roma, Tx
    When the check engine light is on I notice a loss of about 10 pounds of boost
  6. Flybynight2
    Flybynight2 Bobtail Member
