COF9670 Front Jacking Point
Discussion in 'International Forum' started by farmersamm, Sep 8, 2011.
  1. farmersamm
    farmersamm Bobtail Member
    11
    Sep 8, 2011
    New to the forum. Had to buy a truck to haul hay due to the drought here in Oklahoma. I haven't driven since I was 34, and now have to hit the road again to bring in hay for my cows
    Rebuilt the rear suspension, now I'm starting on the front suspension.
    Looking at the truck I can't really figure a safe way to support the front of the vehicle while removing the springs and axle.
    The patient is an 88 coe 9670 that set me back $3800, and is rapidly approaching EIGHT GRAND:biggrin_2551: Tis what it tis I guess. Coulda bought a $10,000 truck and been doing the same repairs.
    There is no clear frame beyond the front spring hangers, so there's nothing to place a jack under. Benind the rear hanger there's no clear frame to place a jack under without removing the fuel tanks, and possibly the air resivoirs.
    The crossmember appears too weak to use as a lifting point.
    All that's left is a pocket in the front spring hanger which seems to be able to accept 2" solid bar stock which can be used as a jacking point.
    Anyone had some dealings with this particular problem??
  3. Heavyd
    Heavyd Road Train Member
    7,756
    6,195
    Feb 4, 2009
    Can you get jack stands behind the rear steer axle spring shackles?
  4. ironeagle2006
    ironeagle2006 Road Train Member
    Do what I used to do with my bosses old JB hunts use the Motor mounts inbetween the axle just do not expect it to hold forever.
  5. farmersamm
    11
    Sep 8, 2011
    I'll check out the motor mounts for a lift point. Thanks
    First on the list today is replacing some exhaust pipe where it exits the turbo. Little bit of welding.
