cold weather mpg
Discussion in 'Canadian Truckers Forum' started by Hughjazz, Feb 3, 2018.
  1. Hughjazz
    Hughjazz Bobtail Member
    32
    17
    Feb 12, 2017
    Hi, it seems silly to ask but I truly don't know what I should be expecting. I've been fortunate to mostly run reefer in the warm summer months, and doing something else in the colder winter season. (construction, or gravel truck work) I just started hauling logs 99% highway.
    My truck is a 2001 t800 525hp N14 18 spd I don't know the gear ratio,but I'm running at 1550 at 100km
    In the summer I average about 6 mpg. One way is loaded at about 33,000kg other way is empty this is in the rocky mountains. Kelowna to Edmonton then back.
    I just did my first rounder hauling logs at 47,000kg one way loaded one way empty. My mileage for the trip was 4.65. Seems low. However the temp was -20C the whole time. I know for sure there was about 4 hrs idling in there too. Normally I don't idle if the truck not moving. (summer) I had an air leak on the trailer so I kept the truck at fast idle to keep the pressure up so the brakes wouldn't freeze.
    I guess I'm wondering if this mileage is "normal" or if I have something wrong here. The truck ran great and has more than enough power.
    Thanks
  3. Western flyer
    Western flyer Road Train Member
    2,807
    6,796
    Mar 13, 2014
    I thinks it's normal.
    I'm in a brand new peterbuilt.
    Seems like every time I go north into cold weather
    I get about a mile per gallon less than I do in the warm weather.
    Don't ask me why,I'm just a certified steering wheel holder.
    Oldironfan Thanks this.
  4. sirjeff
    sirjeff Medium Load Member
    Your numbers sound about right
    When I was going to edmonton from kelowna with a tridem up to weight, I'd be about 450 there and 400 or so back? That was loaded both ways in warmer weather mind you.
    Btw 1550 at 100 i bet your ratio is 4.10ish (if you have 11r22.5 rubber)
  5. Runawayscreaming
    Runawayscreaming Medium Load Member
    324
    321
    Nov 24, 2011
    Amiskwaciy Waskahikan
    At -20 tire rolling resistance is increased because tires become less flexible the colder they are. Any ice on the road will also decrease your mileage, due to micro-slippage. That includes ice that is not visible, like the frost from ice fog or airborne ice crystals in northern Alberta, for instance.
    Pulling a loaded Super-B (lots of tires) away from Watson Lake on the Alaska Highway after it has been sitting for the night at -40 is like having a third trailer. After about half an hour of driving the tires will warm up (from internal friction) and have less rolling resistance but will remain comparatively slow as long as the temperature is low.
    There are winter tires that roll better (and stick better) at low temperatures but the treads are made of compounds that wear like pencil erasers if the temperature goes up or if you are driving south.
    Deep blocks (knobbies) on winter tires decrease your mileage because the block flexes (which is what makes the block stick to icy roads). The warmer it is the more the block can flex.
    Your mileage can also decrease slightly if your engine is running cold. That is possible if you are empty and you have an insufficient winter front. Keep an eye on your water temperature, especially if it is -30 or -40.
  6. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    In Michigan hauling 157,000 pounds with a n14 500ish power 13 speed truck avg 3.8 mpg for round trips. This was a 8 axle double trailer combo. Truck ran 1700 rpm at 68mph.
  7. easytopleez33
    easytopleez33 Light Load Member
    251
    325
    Jan 6, 2015
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,297
    Apr 9, 2009
    Humboldt, Sk
    Trucking Today magazine a few years back did a good article on the science of winter fuel economy.
    The difference from summer to winter blended fuel accounted for about a 4% drop in mpg.
    Stiffer drive train was another 1 or 2%.
    The biggest factor was the air temperature. Cold air is a lot more dense than warm air. It takes a lot more power to push that dense air mass out of the way. They figured it accounted for about 15% of the drop in mpg.
    So adding it all together, about a 20% drop.
    You had 6.0 in summer less 1.2 (20%) = 4.8 mpg.
    So you are pretty close to normal.
  9. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    I lose around 1 mpg in the winter also. I pull heavy too but on flat ground so its easier on fuel. I would try to get to 5 mpg. That should be doable with a n14 if you drive for fuel mileage. That amount of idling won't have a huge effect on your mileage. Never shutting the truck off for days on end will drop it a noticeable amount.
  10. Runawayscreaming
    324
    321
    Nov 24, 2011
    That is a good point about the cold air. If you are sailing in the Southern Ocean the cold, dense air from Antarctica makes you go faster!
    Oldironfan and uncleal13 Thank this.
  11. Oldironfan
    5,776
    5,544
    May 22, 2017
    Cold air is good for power.
    Hot air is good for mpg.
    BigHossVolvo and uncleal13 Thank this.
