Cold Weather Super Trains-Need Diff. Release Agents for Winter?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by MCIRoger, Dec 7, 2021.
  1. MCIRoger
    MCIRoger Bobtail Member
    Dec 7, 2021
    We Haul allot of Super Train loads around Michigan and find that when the weather gets in the lower temps our bulk loads a manure/gypsum etc. will freeze up in the trains. Any trade tips on things we could use to help with this issue. Appreciate it.
    Note: Brine was mentioned as a method but will not work in all cases
  3. beastr123
    beastr123 Road Train Member
    2,917
    23,903
    Jan 2, 2014
    Moose Jaw SK CAN
    Load dry as possible and if you own the trailers mount a bracket on each hopper and use a vibrator such as a vibco 55-3 or a 55-2. It will help a bunch with the gypsum if it is dry but only a drier product will help with a manure load.
    If you are running end dumps mount the vibco near the back in the middle.
    My CV last job had a dry bulk division, grain ,fertilizer,salt,sodium sulfate among other products. We used vibcos on all trailers.
    snowman1980 and MCIRoger Thank this.
  4. MCIRoger
    Dec 7, 2021
    That's great info. Exactly what I was hoping for. Thank you sir!!
    beastr123 Thanks this.
  5. beastr123
    2,917
    23,903
    Jan 2, 2014
    Moose Jaw SK CAN
    If you are running hoppers a 12 or 15 inch square 3/8 thick or better with angle brackets welded to allow you to slide the Vibco onto each hopper.
    Weld the plates to each hopper about 8 inches up from the bottom and plumb a air line fitting close to center between the brackets and use a 1/4 turn valve to regulate the speed of the unit.
    snowman1980 Thanks this.
  6. Magoo1968
    Magoo1968 Road Train Member
    2,050
    5,466
    Mar 18, 2021
    St Malo mb
    If possible unload the same day you load . A truck parked in yard a day or two is frozen most times.
    MCIRoger and beastr123 Thank this.
  7. abyliks
    abyliks Road Train Member
    3,997
    9,401
    May 2, 2010
    ludlow MA
    As long as your not running feed we used to cut the release stuff with 911 power service, 35 ton frozen in the double plastic, double sprayed trailer in st ambrose Quebec in winter taught me that one.
