Columbia 14L Detroit VPOD question
Discussion in 'Freightliner Forum' started by wuboring, Oct 11, 2017.
  1. wuboring
    wuboring Bobtail Member
    Oct 11, 2017
    Bought a 04 Columbia with a 14L Detroit as a grain hauler, ran great the first two weeks we used it but I am starting to have problems with it.
    Problem 1 was I got a PID 354 Code. I replaced the Relative Humidity sensor and the code went away. The sensor was clearly broken upon visual inspection.
    Problem 2 is a SID 060 code. Ive looked it up to find its a PMW #4 open circuit which leads me to the VPOD.
    The symptoms of the truck are as follows: When we first took delivery at idle the truck sounded like a jet engine. A few trips before it through the SID 060 code I noticed at idle the jet (turbo) noise would fluctuate and somewhat cut in and out and it sounded like the boost was increasing and decreasing without any input from the throttle. At that time the truck ran fine. Then without any other notice I took off loaded and it seemed like my power was way down and I can hardly hear the engine boosting at all. At idle there is no turbo noise. Upon return from that trip I checked codes to find the SID 060. I am heading out now to check the VPOD for loose wires, ect. Is there any thing else I can inspect without a laptop that has the Detroit software? Should I just get a new VPOD harness since the detroit book says SID 060 is an open circuit?
    Sorry for the long post, I am just trying to provide as many details as possible
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    Yes on the short harness to VPOD. Those and VPOD's are common fail items.
  4. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    Believe it or not when everything is working correctly they sound like a jet engine when they idle.
    If you don't hear that sound apoun idle something is wrong....
    BoxCarKidd Thanks this.
  5. wuboring
    Oct 11, 2017
    New VPOD fixed it, I installed a new harness too because the connectors were looking questionable. Thanks for the help
  6. Shortyraw
    Shortyraw Bobtail Member
    I have an 06 freightliner columbia 60 series detroit in it . So the problem im having is under a load going uphill or on a flat road around 6th gear the truck jerks blows some black smoke then clears up sometimes after a longer haul when i rea h my destination the truck runs super rough and blows alot of black smoke does this sound like a v pod issue appreciate the feedback
  7. StrokerTSi
    StrokerTSi Medium Load Member
    532
    777
    Aug 28, 2016
    Sounds like the link on the turbo the vpod controls is worn out, mine did that when I was messing with the adjustment on it.
  8. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    Near the turbo there are two steel tubes ( 1/4 " ? ) that come up to a sensor mounted on a bracket. There are rubber hoses between then. Be sure nothing is broken or stopped up. After that you probably need to find someone with a scan tool. JMO
  9. BigByrd80
    BigByrd80 Bobtail Member
    Fayetteville NC
    Where is the VPOD located on 14 liter Detroit
  10. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    I thank they had two. Passenger side between the frame and engine behind the axle.
