Columbia 2007 detroit 14 L turbo options?
Discussion in 'Freightliner Forum' started by Verdel, Aug 14, 2014.
  1. Verdel
    Verdel Medium Load Member
    596
    135
    Oct 26, 2013
    My turbo is acting, some times works then stops. I may need a new turbo soon. Is there any options for less expensive turbo like the one on the old Detroit 12.7 ($500). I asked at Detroit Diesel, they quoted me around $2000 only for the part.
  3. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    No, you're stuck with it. They tend to make loud and weird noises when they are bad. I've seen it a few times already. Especially at idle, or taking off. You would need additional after market programming with a non VGT turbo, that is a no no to talk about.
    Verdel Thanks this.
  4. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    thre is anohter option. found out wht the OEM turbo is, find one that is campareable and bolt it one,migh tbe cheaper than going to a Detroit dealer
  5. Verdel
    596
    135
    Oct 26, 2013
    Do you know any shops doing that?
  6. Verdel
    596
    135
    Oct 26, 2013
    I am considering this option. In fact I have seen some, but I don't know how reliable are they.
  7. bijan1
    bijan1 Bobtail Member
    20
    9
    Oct 16, 2010
    morrisville
    if it is just cutting out you may just want to check the V-pod. I had the same issue and thats all it was a $200 part. Start with the smallest fix first
    Verdel Thanks this.
  8. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    unfortunatly VNT turbo is so expencive for any US ore EU engine...
  9. mhyn
    mhyn Road Train Member
    4,255
    4,512
    Dec 29, 2008
    Northridge, CA
    I have a turbo for sale..was on truck one day only, p/n 23534361. retail 2300 I can go for 1000..reliabilt brand
  10. Verdel
    596
    135
    Oct 26, 2013
    Thank you, after replacing the delta P sensor, now is working, but I will have this in mind next time.
