I have a comfort pro apu. Everyone tells me I can have it turn my truck on or something when my trucks volts get to low, so my fridge that runs on my truck wont die half way threw the night. But no-one tells me how to do it I tried playing with all the bottons with no luck. Someone
Help please.
Comfort Pro Apu problems I can't figure out?
Discussion in 'Experienced Truckers' Advice' started by AlmostSuperman, Sep 9, 2018.
www.apucenter.com can answer your question.
It won't start your truck , but it(apu)should start and charge your batteries. I haven't had a Carrier apu in a long while. What you need to do is set the battery monitor so it will start the apu at the desiered point.
You should be able to find this setting in the display.
It will probably say voltage setting it will alow you to set the low point for the batteries like 12.5 or whatever.
If you can't find it in the settings type SETTING BATTERY MONITOR ON A CARRIER APU into the search box on your home page you'll get a bunch of results you can sift through.
Including a PDF download of the manual.Last edited: Sep 10, 2018
There is several things to look at
- That you are not “locked out” of the key menu items with password protection
- That the “Battery Monitor” function is On (should see a “battery” in the top of the display screen)
- That the voltage threshold is set to where the APU will come on to charge BEFORE circuits start shutting off (like power for the fridge)
- That the voltage calibration is properly set (in the APU)
First calibrate your Apu. Take a reading of your batteries with a voltmeter, then input that number. Then go to your battery monitor setting and then adjust where youd like the Apu to kick on when the voltage drops to that point.
