Coming in clutch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Sandsailor, Aug 1, 2023.
  1. Sandsailor
    Sandsailor Bobtail Member
    21
    9
    Feb 26, 2023
    What are the options for clutches? I think mine might be on its way out and I’m looking around for higher torque rating. I’m running a C15 acert with 16:1 compression and a tune. It runs at around 55-59psi, plenty of power. I don’t abuse it, but I would like a clutch that would last. I know about the 2050 Eaton clutch, that’s the standard and I heard of people running plenty of power through them. I also know about the PDI 2400lbs clutch. Just wondering if there’s anyone else that make good clutches that will run reliable and not break my leg trying to use it daily.
  3. MRMTRANS
    MRMTRANS Medium Load Member
    393
    428
    Apr 28, 2015
    Eaton Easy Pedal. I have 1650 ft-lb torque engine, but went with a 2000+ft-lb torque Easy Pedal (don't remember exact torque rating) instead of a 1700 ft-lb. It's easy to push in. I'm told by my mechanic whose very experienced that they hold up fine.
    Big Road Skateboard Thanks this.
  4. W923
    W923 Road Train Member
    1,388
    4,263
    Feb 28, 2022
    I have a truck that comes to my shop similar numbers to the op and a 2250 eaton clutch won’t hold it reliably once things glaze up a little. i don’t know what to recommend just sharing that.
