Coming to Maverick in a week or two after a long break from driving.
Discussion in 'Maverick' started by Doyne, Feb 9, 2013.
  1. Doyne
    Doyne Bobtail Member
    46
    11
    Feb 6, 2013
    Fairfield, Pa
    I am going to be going to orientation within the next few weeks, hopefully. I have been waiting for a spot for several weeks now. I have not driven otr for 12+ years. I am 61 yrs old in fairly good shape and will be in the glass or reefer division. So, my questions have to do with making the grade in orientation.
    Of course I have heard all the horror stories about lifting 120 lbs over your head and stuff like that. I don't put much stock in that but I do expect to be tested in the area of lifting etc. I dont really have any worries about being able to lift 40 - 80 lbs onto the back of a flatbed but with all the stories I would like to know the facts in regards to glass and reefer. I know that I will probably get a spot in reefer but glass is a possibility.
    Can anyone give me some inside info on the orientation process? Thanks in advance. I really enjoy reading the post here.
  3. BigMod34
    BigMod34 Light Load Member
    64
    33
    Jan 26, 2013
    Minneapolis, Minnesota
    I'm waiting to hear from Maverick, I'm hoping to get into their glass division as well. Maybe I'll no something by Wednesday. Good luck.
    Doyne Thanks this.
  4. Danfromwindsor
    Danfromwindsor Road Train Member
    1,632
    614
    Mar 26, 2010
    The "horror" story of 120 over your head isnt too far off. Its about half that if i recall correctly. There are a couple of threads here that are pretty detailed. I recommend reading them. Everyone regardless of division goes thru the flatbed physical just in case you are needed to pull flats i guess. A lot of reefer guys think this is unfair but it is what it is so they can either do the physical lifting or go home.
  5. BigMod34
    64
    33
    Jan 26, 2013
    I shoulder press 135lbs, 5 sets of 10...I'M READY!
  6. Razororange
    Razororange Road Train Member
    2,593
    24,754
    Dec 20, 2011
    Milwaukee, WI
    You don't have to do 120 over your head. The 120 is only a dead lift to knuckle height and then set it back down. Make sure you use your legs to do the lifting during this or you will get to do it again.
    There was also a 60lb box that you pickup overhand by handles sticking out of either side. You have to lift it over you head and then set it back down in a controlled manner without going too fast or allowing your arms to shake a whole lot while doing it.
    I'm doing glass and will finish my training tomorrow. Danfromwindsor already linked to my thread earlier. Everything in there is exactly as it happened for me in the 2 weeks I've been here. If you have any question you can post here, my thread, or send a PM. I'm happy to answer any questions about their current orientation process.
    Good Luck and hope to see you on the road here soon.
    raetnrunner and Doyne Thank this.
  7. Ridgerunner665
    Ridgerunner665 Road Train Member
    2,131
    1,047
    Apr 27, 2009
    For glass...Schneider made us get a 60-80 pound tarp up on our shoulder and carry it up a ladder...5 people out of 11 got sent home the very first day of orientation because they could not do this.
    There is a trick to doing this...stand the tightly rolled tarp on its end, kneel down, bend forward enough to get the end of the tarp to rest on your shoulder...grab the bottom of the tarp, and sorta roll it up on your shoulder, if you need to move it forward or back so it balances better...bounce it and move it whichever direction it needs to go, but don't overdo it...and get it balanced before you stand back up.
    A slightly altered method that works better for me and my aching back...is to stand the tarp on its end on my knee, that way I can use my knee to help lift it up...and it requires less flexing of the back.
    Being able to do this is required for those places that won't put the tarps up on the glass for you.
    Doyne Thanks this.
  8. born&raisedintheusa
    born&raisedintheusa Road Train Member
    4,321
    4,636
    Sep 20, 2012
    More and more I am seeing on the forum that truck drivers must be able to lift, carry, and maneuver so many pounds of weight in case the need ever arises. I have noticed that 100 plus pounds is not that farfetched when dealing with freight that is quite heavy by nature:
    a) boxed protein - beef, chicken, pork along with frozen foods
    b) crates of produce - fruits & vegetables in wooden crates
    c) hardware - tools, fittings, repair parts
    d) rubber - tires, gasket sealants, floor mats for industrial use
    e) dairy - crates of gallon jugs of milk, cheese, cream, butter, ice cream, along with casein and whey
    f) construction materials - paint, tar, bags of concrete and asphalt, tile, bricks, lumber, plumbing supplies, electrical wiring, plaster, and sheet rock
  9. sarge26044
    sarge26044 Road Train Member
    1,512
    942
    May 24, 2009
    Louisville, ky
    Razororange started a new thread in here and is still in orientation and will be finishing glass securement/tarping portion this week. very detailed description. and brand new perspective. Jim the Hut has a thread from day one over two years ago to present day. Take your pick and read them both start to finish. Enjoy
    Doyne and raetnrunner Thank this.
  10. chemsoldier1
    chemsoldier1 Medium Load Member
    458
    210
    Apr 10, 2011
    Lufkin, TX
    Trucking companies are getting smarter and looking for ways to cut costs in the era of "Obamacare." I'd be willing to say that the days of the 400lb slob sucking down Pilot chili dogs in his underwear while waiting for the lumpers to finish might be coming to an end.
    jxu417 Thanks this.
