Company assigned me a Frt Cascadia. Help.
Discussion in 'CB Radio Forum' started by jcal88, Jan 6, 2013.
  1. jcal88
    jcal88 Bobtail Member
    32
    8
    Oct 21, 2012
    On the interstate
    The company I am currently assigned me an '09 Cascadia. My biggest problem, is whoever before did what they did. The stock mounts for antenna (driver side), and the cb mount cubby are completely useless. They are torn up so bad, I can't use them. I've started thinking of a few ideas for the antenna, but what to do with the cb? If you've got sound advice, please let me know. Thanks.
  3. mike5511
    mike5511 Road Train Member
    3,140
    1,523
    May 15, 2011
    NW Arkansas
    I don't have time to get into details right now, but do a little search using "cascadia" and you will find a bunch of info on here.
  4. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    I run a bird purch , it replaces one of the mirror bolts on the drivers door. Run cable in at door hinge nd up behind door post trim, and over to the cb.
  5. jbee
    jbee Medium Load Member
    664
    619
    Jun 3, 2011
    NC
    Did the same with a Wilson top loaded antenna.
  6. jcal88
    32
    8
    Oct 21, 2012
    On the interstate
    I bought a mount from Walcott cb. My issue now is where to put the radio. The cubby that is made for it is completely torn up and useless.
  7. mike5511
    3,140
    1,523
    May 15, 2011
    NW Arkansas
    Freightliner makes a plate that fastens to the dash to mount a radio on. I'd rather have one on the dash as overhead myself. If you can't mount a plate, use velcro. I've also seen guys get creative with a piece of plywood and bungie cords.
    jcal88 Thanks this.
  8. jcal88
    32
    8
    Oct 21, 2012
    On the interstate
    I'll have to ask my boss about that. Thanks for the ideas though.
  9. mike5511
    3,140
    1,523
    May 15, 2011
    NW Arkansas
    Sometimes it is easier to get forgiveness than permission!
  10. BigByrd47119
    BigByrd47119 Light Load Member
    86
    21
    Jan 3, 2013
    Velcro is, in my experience, more than sufficent if the surface is prepped properly (alcohol wipes on both surfaces to have velcro applied to, continue to clean until no more dirt comes off). Craft stores sell "industrial" strength velcro that is probably 1 and a half times to two times better at holding and sticking than the truck stop stuff from.my observations.
    jcal88 Thanks this.
  11. jcal88
    32
    8
    Oct 21, 2012
    On the interstate
    Ya. I'm thinking Velcro might be the way to go. All I gotta do now is figure out where to run the wires. Which shouldn't be too hard.
    BigByrd47119 Thanks this.
