Compartment loads - tanker
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by 59EX, May 3, 2017.
  1. 59EX
    59EX Medium Load Member
    407
    631
    Jun 27, 2015
    This is a new one for me...
    Riddle me this.
    If I'm doing a 3 compartment load that I'm pumping off, and the customer doesn't have a way of telling me their tank level, what is a good way to tell when I am empty on each compartment. I can't climb on top of the tank...prohibited.
    TIA.
  3. HD5
    HD5 Bobtail Member
    33
    42
    May 27, 2014
    Canyon lake, Texas
    Are you using a pump?
  4. 59EX
    407
    631
    Jun 27, 2015
    Yes.
    I don't see how the suspension gauge is going to do me much good either...
    One load is compartment 1/3, the other is 2.
  5. HD5
    HD5 Bobtail Member
    33
    42
    May 27, 2014
    Canyon lake, Texas
    Does your pump change tone when it runs dry or cavitates?
    RockinChair and slim shady Thank this.
  6. wsyrob
    wsyrob Trucker Forum STAFF Staff Member
    5,769
    5,463
    Sep 14, 2007
    Winston Salem
    Hope you have a way to vent the tank since you cant climb on top. I would probably use a blow down fitting and check it there after walking the hoses a few times once they go slack.
    slim shady Thanks this.
  7. HD5
    HD5 Bobtail Member
    33
    42
    May 27, 2014
    Canyon lake, Texas
    Sometimes when the plant is noisy and I can't use gauges I have to put a screwdriver on a hose clamp and rest my ear on it. Like a redneck stethoscope. I can hear flow real good though. Operator at the Valero refinery in Three Rivers TX showed me that little trick.
    RockinChair and scythe08 Thank this.
  8. slim shady
    slim shady Road Train Member
    3,468
    14,690
    Sep 14, 2011
    Chicago, Il.
    How are you going to vent it?
    Do you have vapor recovery if so that'll work.
    Listen for a chanve in the sound of the pump.
    My pump will bounce my hoses a little bit when mt.
  9. 18 wheels of fury
    18 wheels of fury Light Load Member
    167
    87
    Oct 31, 2015
    Houston
    well you need to go up and vent the tank if that's not a option usually the pump gets a little louder when you empty a compartment
  10. mustang190
    mustang190 Road Train Member
    2,846
    6,115
    Jan 18, 2011
    Florida Panhandle
    Unless your tank has a vapor recovery line, no need to go on top.
    Once you start off loading feel how heavy the hose is. When it's empty it's lighter.
  11. RockinChair
    RockinChair Road Train Member
    5,103
    12,876
    Feb 19, 2012
    CC, TX
    Hold your hand over the VR opening. When the compartment goes empty, you'll feel a reduction in the amount of air being pulled into the trailer.
