Computer programs for trucking..
Discussion in 'Questions From New Drivers' started by teachmebouttrucking, Mar 4, 2008.
  1. teachmebouttrucking
    teachmebouttrucking Light Load Member
    88
    Feb 6, 2008
    Asheville, NC
    Are there any computer programs that you guys use to help keep up with stuff like log books, or miles or anything that could be helpful to put on my laptop.
  3. brinkj23
    brinkj23 "Asphalt Cowboy"
    1,165
    322
    Dec 26, 2005
    Minnesota
    Get microsoft streets and trips with the gps. It will show you exactly where you are. Great tool for trip planning the night before to, you can see where you will be turning and what the streets look like in the area. Remember though its used as a referance against your trucker atlas and directions from your company.
  4. evolutioncalling
    evolutioncalling Medium Load Member
    315
    11
    Jan 19, 2008
    Atlantic Beach, FL
    Ditto on Microsoft Streets & Trips. Also, for logging you can use Drivers Daily Log software. Some companies, like Roehl, have certain logs they want you to use but you can use DDL to double check your work.
  5. evolutioncalling
    315
    11
    Jan 19, 2008
    Atlantic Beach, FL
    Oh, I also have the Neat Receipts scanner and software to keep track of any expenses.
  6. trucking_on_through
    trucking_on_through Light Load Member
    85
    5
    Dec 15, 2007
    Los Angeles, CA
    There is a free plugin template for Streets & Trips that incorporates weigh stations, low clearance warnings, truck stops, Walmarts, ect... it is
    a free template, but since URLs are discouraged on this board, do a Google search for Largo Software. Once on their site, look on their main
    navigation bar for "Map Templates". Not affiliated with the site, but I will be using this once I am out on the road, with my Motor Carrier Atlas.
  7. jlkklj777
    jlkklj777 20 Year Truckload Veteran
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    Alk Technologies created Pc Miler software and the Co-Pilot program which were specifically created for the trucking industry. The software is kind of expensive but worth it as it does route you on truck approved routes and avoids low underpasses. The C0-Pilot program has a gps module that plugs into a usb port on your laptop and has the capability of giving turn by turn directions as well as spoken commands.
    Maps and Trips is very good IF your driving a car. If you use this software be very careful as it does not route you around restricted routes nor low bridges.
  8. evolutioncalling
    315
    11
    Jan 19, 2008
    Atlantic Beach, FL
    Before investing in mapping software, make sure the company you are looking at doesn't provide your route for you. Granted you have to verify the route, but just keep that in mind.
  9. soundman
    soundman Light Load Member
    110
    18
    Aug 20, 2007
    PA
    Does Co-Pilot work with the USB GPS receiver that comes with Street Atlas?
  10. jlkklj777
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    I cannot answer your question as I have not purchased the Co-Pilot program. I use the Pc Miler mapping program which is a stand alone program that does not require a gps module.
    You can do an internet search and check with ALK Technologies directly. Last I knew their co-Pilot program was running about 300 bucks including the gps module.
  11. Pur48Ted
    Pur48Ted Road Train Member
    3,643
    5,981
    Jun 14, 2006
    Grand Rapids, MI
    I use DriversDailyLog program (google it). It will keep expense records, ifta fuel tax, days out, fuel records, PLUS do your logbooks (among other things) I have been using it for over 10 years.
    HERE is what the LOGS look like: http://www.thetruckersreport.com/tr...my-logbook-violation-question.html#post363259
