This may be the wrong forum for this question, not sure pretty new here and seems mostly TL info. Anywho seems like a good company, lots of dock work and BS while on flex board but....Anyone work there or have any comments good or bad is surely welcome...thx in advance
Con-way LTL...Good choice?
Discussion in 'Con-Way' started by larry66, May 6, 2010.
What exactly is your question? You thinking about coming aboard, or are you already onboard with Conway?
S~ -
I'm going thru the interview process now, actually on Monday they want me to do road test, physical and drug test, so im into it a bit, seems as if all that checks out and it should a job offer will come.
So if you run line-haul then you get paid so much per mile, which consist of pulling doubles to said location, swap out with another driver from another terminal then back to your terminal. Then you work the dock which consist of using a forklift to situate the cargo in the trailer so that the city driver can come in in the morning and pull his stops off in sequence? And this is how ltl works in a nutshell? So you are paid mileage and hourly?
sandal0906 Thanks this.
No job is perfect....Conway is not the best job in the world and its not the worst...but its 100 percent better than otr.... I am coming up on my first 90 days with conway and it has been ok....dont like working nights but its better than being unemployed...Yu will make a decent living working at conway...good luck ...
jakebrake12 Thanks this. -
JakeBrake, I was wondering if you knew if Conway checks DAC report. I already went in for an interview and have a physical and drug test this week once I am off the road with my current company. I recently had an accident at a Wal-Mart DC (forgot my tandems were slid to the rear and doors were open) and I knocked off one of my trlr doors. I was told it will go on my record as a preventable minor accident. Should I worry about this? Hopefully Conway Freight has already pulled my DAC and ok'd it, but if not, is this something to worry about. Don't know how picky they are on accidents.
Just make sure you tell them. One thing they don't tolerate is falsifying your application. I've been here three yrs and never work the dock. I come in about 0700-0800 and make a short local run or two. By then my trailer is ready and I run my route from about 1200-1900. Then I may run another drop and swap before getting off around 2030. That's usually how it goes right now while we are so busy.
