Conflicting weigh station bypass
Discussion in 'Questions From New Drivers' started by Redtwin, May 23, 2017.
  1. Redtwin
    Redtwin Road Train Member
    5,487
    7,606
    Aug 17, 2012
    PBC, FL
    At a couple weigh stations that have the illuminated signs telling to bypass or pull in as you drive past them I have gotten a green bypass signal on my pre-pass but the roadside sign signs says to pull in.
    Which one would you obey?.
    G13Tomcat Thanks this.
  3. prosidius
    prosidius Light Load Member
    252
    239
    Jul 15, 2016
    Wisconsin
  4. driverdriver
    driverdriver Road Train Member
    4,254
    5,283
    May 30, 2011
    Pre pass for you, pull in for trucks not equipped.
    Redtwin Thanks this.
  5. G13Tomcat
    G13Tomcat Road Train Member
    11,872
    42,142
    Jun 7, 2011
    Disagree; electronics can be off, timewise.
    There was a thread on this, a while back.
    @scottied67 .... don't know if it was yours or not.. believe you had a say in it?!?
    noluck Thanks this.
  6. noluck
    noluck Road Train Member
    1,616
    11,683
    Jun 10, 2011
    greenville,sc
    No it does not! If you get the sign to go in you'd best put on your blinker!
  7. driverdriver
    4,254
    5,283
    May 30, 2011
    The sign is lit for trucks not equipped with pp... If you have Pre pass and get the green your good to go.
  8. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Some states have signs telling you what to do. I've seen signs telling pre pass trucks to follow in cab signals. I think I've seen that in Washington?
  9. driverdriver
    4,254
    5,283
    May 30, 2011
    Yep.
    It's posted in several states.
    noluck Thanks this.
  10. G13Tomcat
    11,872
    42,142
    Jun 7, 2011
    Ohio does this in a few places, as well. You are correct.
    noluck Thanks this.
  11. noluck
    1,616
    11,683
    Jun 10, 2011
    greenville,sc
    That's somewhat true! However, you do not know if they hit the button for you to come in. Just like bypass arrows. If you pull into a ga scale with an oversize. They may give you the bypass arrow, but the signs says for os to scale. You best go to the scale. Can't always trust that arrow or prepass.
