Connex. 4300 hp my for service Manual
Discussion in 'CB Radio Forum' started by Batrobes, May 24, 2018.
  1. Batrobes
    Batrobes Bobtail Member
    9
    4
    May 24, 2018
    Altoona, Wi
    People say cb tricks had it but they do not. I had my radio peaked and tuned at the q5 cb shop in Madison WI. Well he did what he said he does not do. And turned my radio down, went from getting 21 miles on a good day to 2 miles if I'm lucky. I have the equipment to peak and tune the radio just couldn't find a service manual for it so I paid him to do it.
    Any help would be appreciated thank you
    rabbiporkchop Thanks this.
  3. wolverine11
    wolverine11 Road Train Member
    1,629
    1,234
    Apr 1, 2015
    Does your equipment include a accurate meter that measures deadkey,pep power,and modulation % ?. If yes what are the readings ?
  4. Triple Digit Bullhauler
    Triple Digit Bullhauler Heavy Load Member
    927
    1,263
    Sep 6, 2012
    001 anywhere USA
    Should have used Konnection electronics in Waukesha, Wi. Larry is fabulous. Small shop, but does great work, without the B.S.
  5. Ridgeline
    22,365
    115,985
    Just get it to a good shop that will align it right, having a service manual with no knowledge of what your doing is disastrous.
    rabbiporkchop and wolverine11 Thank this.
  6. wolverine11
    1,629
    1,234
    Apr 1, 2015
    Cant believe Q5 messed it up, forum member Volvo has highly recommended them and if he transmits and receives 20+ miles in a cascadia thats good enough for me.
  7. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    Yep, turn power down, clip the limiters and add a b.s. super mod kit. Typical hack job. All overmodulated mouth and no range..
  8. Batrobes
    9
    4
    May 24, 2018
    Altoona, Wi
    I'm not sure on the exact equipment it's my old man's, he has a pretty nice digital oscilloscope and old school watt meter with the slugs
  9. Batrobes
    9
    4
    May 24, 2018
    Altoona, Wi
    I drive day cab and that is the only shop I go by every once in a while
  10. wolverine11
    1,629
    1,234
    Apr 1, 2015
    If you were transmitting and receiving 21 miles why the peak and tune?
  11. Batrobes
    9
    4
    May 24, 2018
    Altoona, Wi
    Because it sounded like #### and was over modulating when I had it hooked up to the oscilloscope. Was there originally to fix an Intermittent audio issue
    wolverine11 Thanks this.
