Container trucking and HOS
Discussion in 'Questions From New Drivers' started by MapTrotter23, Jul 11, 2013.
  1. MapTrotter23
    MapTrotter23 Bobtail Member
    25
    I was just wondering, do container trucking driver, drivers that haul port containers from ports, have to follow the same Hours Of Service rules that interstate drivers do? This might be a stupid question, since I'm not sure whether container truck drivers are interstate or not.
  3. freightrunner
    freightrunner Heavy Load Member
    722
    182
    Mar 25, 2012
    Georgia
    Yes. Don't quote me on this but I think oilfield drivers are the only ones exempt because of long loading times.
  4. MapTrotter23
    25
    So, do most container truck drivers drive interstate?
  5. freightrunner
    722
    182
    Mar 25, 2012
    Georgia
    Not really. Since there are rail yards in most major cities and trains, there is no reason to..
  6. MapTrotter23
    25
    Oh, but then why are they required to keep HOS logs?
  7. haulhand
    haulhand Road Train Member
    Everybody is required to keep som form of an HOS record whether its a logbook or a time sheet. Most oilfield drivers keep a logbook and are subject to the San HOS limits as Everyone else with a fe exceptions. Local Drivers that stay within a 100 airmail radius don't need w logbook unless they get out of that radius or work over 12 hours.
  8. rockee
    rockee Road Train Member
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    What Haulhand said. I don't think it matters weather your interstate or intrastate you still have to follow the HOS. I would venture to say that almost all of your container haulers are classified as interstate weather they get their can from a port or rail yard. Being classified as intrastate does not just include "you" crossing state lines, it also matters if your freight will/has crossed state lines or has originated or is destined out of country. So you can be a can hauler in the middle of Nebraska, never go farther than a mile from the rail head and still be "interstate".
    Container Hauler Thanks this.
  9. MapTrotter23
    25
    That is really helpful Rockee. Thanks
  10. wis bang
    wis bang Road Train Member
    3,409
    4,027
    Jan 12, 2011
    Levittown, PA
    I used to have ten terminals; a percentage of each were line haul w/ RODS while all the local guys were under the 100 air mile exemption.
    To account for their HOS; since we were using a scanning service, the air mile guys showed thier time on line 4 w/ the words 'Time Record' written above.
    When the DOT audited, the lady only wanted to see the line haul guys.
    75% of ours were air mile guys and they were ignored.
    My trucks do not leave the 100 air mile circle often now.
  11. KMac
    KMac Road Train Member
    3,427
    3,067
    Jan 26, 2012
    Waxahachie, TX
    Same HOS, and depending on location... container work is Interstate... have a friend back home hauling bananas out of the Poet of Wilmington, Delaware... if you have ever been through there you know you wills be in a different State before you hit top gear. He runs from Virginia up through the Northeast I believe.
    HOS is the same although some companies can elect to use the 60hr 7 day plan
