Continuity through the Power Prongs?
Discussion in 'CB Radio Forum' started by theflyingvaliant, Jul 7, 2017.
  1. theflyingvaliant
    theflyingvaliant Bobtail Member
    5
    Hey, guys. I just bought a Cobra 29 LTD classic. I've tested the continuity for my 102" whip antenna and coax. Everything on the system that should have continuity has it, and everything that should be open is open from the coax up front to the antenna and base. I plug the coax into the back of the CB and everything still reads the same until I plug in the power.
    As soon as I plug in the power, I have continuity between the base and the antenna all down the line. I checked the power feed from the 12 power to the back of the three prong plug for the unit and there's nothing. If I test the power prongs on the back of the CB, I get almost full continuity. I popped open the back of the unit to see if there was a short, and there's a small, flat, yellow capacitor soldered to the back of each prong leading to a ground spot on the back of the unit. That seems to be where the continuity is coming from.
    If I unplug it, everything goes back to normal. Hots have continuity, grounds have continuity, but between the two, they're open. Is this normal? I'm a complete noob here, so any help would be greatly appreciated.
    Thanks!
    Chuck
  3. bored silly
    bored silly Road Train Member
    2,714
    656
    Jul 1, 2016
    Does that/your radio power up. Hmmmmmmm ?????
  4. theflyingvaliant
    5
    Yes. It powers up and runs normally, but my SWR pegs off the charts no matter how I calibrate it.
  5. Ridgeline
    22,204
    113,964
    Your going in the wrong direction.
    The continuity doesn't matter when the radio is hooked up, the SWR indicated that there is a problem with the antenna and only the antenna. Those caps are there to suppress spikes and protect the system and if they were bad you would blow a fuse as soon as you hook it up.
    You said you have a 102" whip, so I would do this, go find someone who has an antenna analyzer and have them hook it to the antenna to see what you are really getting in an SWR reading. They may have to hook it right up to the antenna base to see what the antenna is tune to, eliminating the coax altogether.
    As a rule - don't really trust that internal SWR meter, go external. AND to add to that, anything below 1.5:1 is good, try to get that because you will have to do some fancy tuning to get better.
    I will also say this - don't take this wrong but when asking a question like this, you gave a great amount of good detail but you left out what kind of vehicle it is which is important.
    Ougigoug and rabbiporkchop Thank this.
  6. theflyingvaliant
    5
    Thanks for your help! All good points and I appreciate the detailed answer. The vehicle is a 1964 Plymouth Valiant that's just finished a frame off restoration. Entirely brand new Ron Francis wiring harness with a grounding kit run to all electrical components. Antenna mount is a steel bracket we fabbed up to go under the bumper for a side mount with a tie down over the driver's door. The bracket has a grounding wire run from it to a copper grounding bolt in the trunk that the rest of the rear electrical circuits tie into. That bolt has an 8 gauge wire running up to another copper ground bolt on the firewall at the front of the car connected to the main ground bus that everything else is connected to.
    Thanks again for the advice!
  7. theflyingvaliant
    5
    Oh, and no, I wasn't trying to calibrate it with the antenna tied down. It was up. I was pulled off on a country road with cow pastures on either side of me. It's Florida so the ground is nice and flat.
  8. Ridgeline
    22,204
    113,964
    Nice car, I loves those A bodies years, the first car I drove was a '62 Plymouth valiant. Alas I ended up with B bodies most of my life, the last car I have out of a bunch is a Plymouth Sport Sat convertible I bought off a friend a couple years back, it doesn't even show up in the records from Chrysler historical, but I've got a broadcast for it. Pretty odd, it is an export with a 273 and a 4 spd with HD suspension and A/C.
    Anywho, you do need to get someone with an antenna analyzer and find out what swr is of the antenna, 102 may be showing up out of tune for a simple issue, like the spring being 4/5 inches and not 6. Or that you need to get a shorty spring. I had one that was exactly 102, it was just like another 102 but I had to use a 4 inch spring with it while the others I used 6 inch springs.
    Also get some braiding for the ground, a wire can act like part of the antenna and throw the SWR off.
    There is a bunch of complicated issues with RF antennas so keep it simple and don't worry about it being complicated.
    theflyingvaliant Thanks this.
  9. theflyingvaliant
    5
    Thanks! That sounds like a wild car. Not too many 273 B-bodies out there, and never heard of anything with those options.
    I switched to a braided ground and man does that seem to make a world of difference. I added a fender washer to "lengthen" the antenna slightly and it did made the calibrations for 1 and 40 true. I was checking last night and the SWR was so low it barely moved the needle and got a response from someone over two miles away. Not bad! Thanks again for the advice. This will really help with my trip from Florida to Pennsylvania. We're leaving Wednesday and I'm driving the Valiant along with my friend's 1964 Dodge pickup and this will make communication between the two vehicles so much easier.
  10. Ridgeline
    22,204
    113,964
    Great, glad it helped.
    You going to the Mopar nats up there in Carlisle?
    I think that's this week or next.
    Say hi to Linda for me. She's supposed to be there this year. AND Hurst nationals are there too, Oh I miss my 300H, it was big but a lot of fun.
