Continuous air leak from air dryer purge valve
Discussion in 'Volvo Forum' started by silver dollar, May 27, 2016.
  1. EverLuc
    EverLuc Light Load Member
    295
    101
    Feb 18, 2013
    So what is the fix? Mine does the same thing now. Sometimes the purge valve leaks and won't allow pressure to build. I have to hold my finger over the hole. Yes, it has a new purge valve, new filter, new governor, new line from compressor to air dryer, new unloader valve/piston in compressor, new treadle valve and new dash valve.
  3. silver dollar
    silver dollar Medium Load Member
    481
    210
    Jan 31, 2009
    Central North Carolina
    The truck i had the problem on has since be put out to pasture due to engine failure. But i ended up changing out the air dryer unit. From a two cartridge type to single. Never found the exact cause within the dryer, just got tired of monkeying with it and changed it out.
    EverLuc Thanks this.
  4. EverLuc
    295
    101
    Feb 18, 2013
    New dryer. Still does same thing. Well, atleast we know what it is not. Ha
    silver dollar Thanks this.
  5. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    Check that the compressor discharge line is not plugged or crimped and check the check valve between the dryer and first tank.
  6. EverLuc
    295
    101
    Feb 18, 2013
    Awesome. Will do. Sometimes at 90 psi it reboots. Sometimes it gets down to 60 before it engages.
  7. EverLuc
    295
    101
    Feb 18, 2013
    Well, after a few weeks of switching valves from one truck to another. The culprit turned out to be 1 of two final replacements. There was a leaking T connector behind the dash that connects to cab suspension switch. Then just for no particular reason, we installed another new governor on the new AD-IS dryer. Darn thing fixed the issue.
    dibstr Thanks this.
  8. Jperez9630
    Jperez9630 Bobtail Member
    I just replece the purge valve on the airdrayer and it still leaking air on my mack 2010 I change the cartridge too
  9. dibstr
    1,308
    932
    Sep 10, 2010
    Check governor, comp discharge line and my personal favorite the check valve between the dryer and first tank.
  10. Jperez9630
