Controlled, Stab, Snub, Threshold braking
Discussion in 'Questions From New Drivers' started by double yellow, Nov 20, 2014.
  1. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Controlled braking: Light (5-15psi), steady brake application combined with proper gear selection when descending a grade at your safe speed. This method was taught for years but is no longer recommended in the manuals. Done properly, it will not smoke your brakes.
    Snub braking: Firm (20-30psi), short (3-5 second) brake applications combined with proper gear selection when going down a grade. Slow to 5mph below your safe speed, release brake, and reapply once you reach your safe speed.
    Stab braking: Hard (90+ psi) brake application, release when wheels lock, reapply when they resume rolling, & repeat until stopped. This is for emergency stopping with old (pre ABS) equipmemt with inexperienced drivers. Still mentioned in many cdl manuals, but is poor technique compared to threshold. This IS NOT used to maintain speed downhill!
    Threshold braking: Firm (30+psi), steady brake application used for emergency braking. Lift slightly if brakes lock until the tires resume rolling (pre ABS) or maintain pressure at which point you feel/hear ABS begin engaging. The goal is to maintain brake pressure at the point just before the brakes lock up. This results in the shortest stopping distance in an emergency.
    Safe speeds for Cabbage Hill:
    Pounds..................MPH
    60,000 - 65,000 37
    65,000 - 70,000 26
    70,000 - 75,000 22
    75,000 - 80,000 18
  3. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    Great piece of info double yellow,thanks.
  4. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    Great! Now what's your question?
    Sik_Life and rockee Thank this.
  5. Ebola Guy
    Ebola Guy Heavy Load Member
    977
    789
    Oct 11, 2009
    Manitowoc, WI
    My question is, when i I am descending a mountain and control my speed by stab braking but the wheels aren't locking up, am I doing it wrong?
    pattyj Thanks this.
  6. HotH2o
    4,098
    4,865
    Sep 23, 2012
    You gotta pull the yellow and red knobs!
    Ebola Guy, littleduck and pattyj Thank this.
  7. Bootsie
    Bootsie Bobtail Member
    42
    47
    Oct 26, 2014
    Syracuse, NY
    Just so I understand, is that before, during or after parachute deployment? And do you recommend single or double parachutes? Finally, I assume color is still the critical factor (we spent 3 full days in CDL school reviewing colors and operating ranges). Sorry for such a basic question but I'm still kinda' new.
    Montgomery and pattyj Thank this.
  8. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    So these brake check areas. Are these just for sleeping and peeing? do they have a purpose?
  9. HotH2o
    4,098
    4,865
    Sep 23, 2012
    Color is a state of mind, Bootsie. As for parachute.....wish I had one...
  10. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    gpsman, Hammer166 and Montgomery Thank this.
  11. Night Prowler
    Night Prowler Medium Load Member
    549
    275
    Aug 9, 2013
    Temple, Texas
    Cant you just use an umbrella stuck out the window ? Or would you need two, one for each window ?
    pattyj and Montgomery Thank this.
