Controlling your schedule?
Discussion in 'Questions From New Drivers' started by Wade73, Jul 5, 2014.
  1. Wade73
    Wade73 Light Load Member
    140
    42
    Jun 11, 2014
    Springfield, IL
    So, how much control do you truckers have over your schedule? From reading, it sounds like most starter companies are forced dispatch which I'm assuming means you have to take whatever load they give you. With that being said I'm a morning person and would prefer to run during the day as much as possible. I know that always won't be possible, and I would have to do overnight runs. I'm hoping I can keep those to a minimum though. Is that possible? How do you control your schedule? Does type of trucking have any impact (dry van, reefer, flatbed,etc.)?
  3. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    Flatbed will be your best bet for daytime running as the general rule. With others, the more grocery hauls you do, the tougher it's going to be maintain a somewhat regular schedule, and with shorter "regional" work you can find yourself having to run varied hours just trying to keep from starving to death.
  4. tnscavenger
    tnscavenger Light Load Member
    259
    215
    Jul 21, 2011
    Maynardville, TN
    Trip planning is key to keeping a somewhat regular schedule. I pull dry vans hauling everything from food stuffs to tires. And although I like running overnight, I found it near impossible to keep it that way because a lot of small and medium shippers/receivers are only open during the day time hours. As an early riser you would have an advantage of finding decent parking in the evening, because rest areas/ truck stops fill up quickly as it gets twilight.
  5. Nattyyd
    Nattyyd Bobtail Member
    24
    10
    Mar 16, 2013
    GSO,NC
    Only thing truckers can control in this industry is the truck on the road, and most of them today can barely do so. Even with careful planning your schedule will get out of wack, unless you have a great dispatch. can plan to drive at 5 am everymorning, but there will be that 1 load that don't deliver till 8am. or get stuck sitting in a door, or truck breakdown.
    NavigatorWife Thanks this.
  6. snowwy
    snowwy Road Train Member
    20,594
    13,315
    Jul 6, 2009
    open during the day so it's impossible to drive at night.
    if you don't drive at night. how you going to get unloaded/reloaded during the day?
  7. oronatrucking
    oronatrucking Bobtail Member
    10
    Jul 18, 2013
    odessa,Tx
    Would it be better driving in teams instead of singles??
  8. oriden953
    oriden953 Light Load Member
    266
    553
    Jul 6, 2012
    winnipeg, MB
    good teams typicly run something like a 9-9 pattern giving each driver some of both.
  9. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    It depends on the company. If you can get the job done then they will give you the more sensitive loads and your schedule can be all over the place. If you drop the ball alot then you will get easy loads and will have plenty of time for "trip planning".
  10. NavigatorWife
    NavigatorWife Road Train Member
    2,937
    2,080
    Apr 30, 2012
    Cental West, AL
    There will be a lot of times you have no choice but to run at night. You might go for a couple of weeks or more, driving during the day and then for whatever reason, the time frame changes and you are driving at night and there is no other way to make pickup or delivery times but to do it this way.
    We did see a woman years ago that worked for USX who would only drive during the day, they must have had her loads flagged in order to do this all the time, and no telling how long a person might sit in an area waiting for the next load also.
  11. marmonman
    marmonman Road Train Member
    1,417
    2,843
    Dec 14, 2009
    central illinois
    A new guy don't get much say in his schedule .
    After almost 20 years with my company I pretty much run my own schedule .
    Since all i do is deliver trailers I don't have to meet any appointments so I run mostly regular hours .
