Convert automatic to standard?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by RollinRupert, Feb 15, 2010.
  1. RollinRupert
    RollinRupert Bobtail Member
    43
    34
    Feb 5, 2010
    Upstate New York
    Is there a wrench in the house that can tell me if an eaton fuller automatic 10 can be converted to a standard 10? :biggrin_25511:
    story:
    No secret I am truck shopin, and I asked some fella why them miles so low? Asked him that the ECM miles? He tell me yes, said the company went outa bizness and the truck sat causin it was automatic, so his wrench convert it to standard, and he had quite a few of them and they been a sellin like hot cakes...............Is this fella givin Rupert the bizness or can conversion be accomplished? Any Eaton Fuller Techs?
    Oxbow Thanks this.
  3. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    in for answer..
  4. Elvenhome21
    Elvenhome21 Heavy Load Member
    735
    240
    Nov 17, 2008
    Sheboygan, WI
    depends which auto it is. if its a ultra shift with the centrifugal clutch then more then likely no. But from what ive read it is the same box it just has a different top plate to accommodate the servos instead of a shifter. The other obvious problem is converting it to a manual clutch/throwout bearing. ive never seen a big truck inside the bell housing so idk what kind of setup they use for a throwout bearing.
    RollinRupert Thanks this.
  5. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
  6. BrainHurtz
    BrainHurtz Light Load Member
    245
    57
    Jun 24, 2008
    Terre Haute, In
    Autoshift still runs a regular clutch and linkage... so cut a hole in the cab and replace the top of the tranny.... maybe futz with the wiring and engine parameters and you would probably be good to go.
    Ultrashift through and you probably wouldn't want to drive it. Trying to downshift would probably be a nightmare.
  7. Mack427
    Mack427 Medium Load Member
    323
    93
    Jan 22, 2009
    if it is a 3 pedal truck meaning it still has a clutch pedal, then yes you can convert it back to a manual 10speed you will have to swap the top of the trans. out
  8. 25(2)+2
    18,756
    45,806
    Sep 18, 2006
    the road less travelled
    I hope you mean pedal not petal. If I were driving a 3 pedal auto shift, I wouldn't dislike it so much.
  9. RollinRupert
    43
    34
    Feb 5, 2010
    Upstate New York
    Thanx fellas and thanx for the link I am gonna make a phone call.
  10. a2madmac
    a2madmac Bobtail Member
    9
    Feb 4, 2010
    Cambridge,On
    I pulled my ultra shift or sh## out last year. Was told by the Eaton rep that converting back to standard was not an option on that tranny. that tranny went thru 2 clutches in 400000 miles.:biggrin_25510: stay away ......
  11. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    Only guy I know personally that had one in a truck had the same problem! It was like a clutch a year for him. His previous truck went 900k on original clutch (lots of cross country trips hauling military equipment on a dropdeck) Sold the lemon and said he'll never own another one.
