convert to auto slacks
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 377pete, Aug 28, 2013.
  1. 377pete
    377pete Light Load Member
    147
    14
    Oct 26, 2009
    dfw
    Want to convert my trailer to auto slack adjusters. Its thas 1 1/2 10 spline 6" manual slack. I just hate that after two or three days I need to readjust. Wich brand you recommend and easiest to set up
  3. wichris
    wichris Road Train Member
    4,436
    9,081
    Jan 17, 2011
    Very little difference in price or set-up between haldex or meritor.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    people say haldex are better
  5. marmonman
    marmonman Road Train Member
    1,417
    2,843
    Dec 14, 2009
    central illinois
    Why don't you just replace them with the kind it has ? slacks are like anything else they wear out too . A good slack wont need to be touched more than 2-3 times a year if ya don't ride the breaks . Just my .02 worth but I wouldn't go to autos unless they made me !!!
  6. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    Personally I like the Haldex better, when you buy them you get a guage, the slack must be positioned properly to work properly.
    I made a tool to lift the button from a standoff bracket, just cut open the end and grind it sharp.
    I took a 5/16 square socket and tacked it into an offset box-end wrench.
    To adjust the slacks you just need at apply 100 lbs of air, when cold and if it is positioned properly it will adjust to the proper spec.
    Just a thought!
  7. Casual Trucker
    Casual Trucker Medium Load Member
    495
    326
    Sep 7, 2012
  8. 377pete
    147
    14
    Oct 26, 2009
    dfw
    Think I am going with the haldex. Anyone know who sells them tbe cheapest
  9. wichris
    4,436
    9,081
    Jan 17, 2011
    Haldex doesn't use the 5/16 drive adjuster or have a button to release the pawl. That's meritor.
  10. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Haldex is easier to set up and adjust. IMO, not any better or worse than Meritor,when set up correctly, both perform well. Haldex is more tolerant of the wrong length chamber rod (shouldn't be an issue, but it is more than you think). It doesn't take much before the Meritor will not adjust, but with a Haldex, it needs to be pretty far out.
    Meritor uses a 2 pin yoke, which isn't bad, just an extra pin to get out when you change a chamber and the yokes are more expensive when you have to change them. You have to lift the pawl button to back the brakes off and it uses a little 5/16" sqaure adjuster. So you need an open end wrench or square socket.
    Haldex uses a bracket to hold the adjuster and has the regular single pin yoke. It uses a 6 point 7/16" adjuster. They take more force to back off, but you can use a regular box end wrench or socket.
    MJ1657 Thanks this.
