converting 9 speed in to 13 speed?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by coadman, Feb 25, 2009.
  1. Rock hauler
    Rock hauler Light Load Member
    264
    54
    Nov 26, 2008
    Deridder La.
    Had that setup in 92 379 425 cat RTXO14613 (had straight shift pattern) not real big HP but not bad it put 592 on the ground at st Louis cat house on 70 west. very fun truck to drive
  3. Hard_times
    Hard_times Bobtail Member
    Wilmington, NC
    I just bought a conversion kit tonight at Freightliner dealer in St. Louis and it cost me $120.00, I have a 9 spd but seems the gears are just too long in them. When you pull long grades it seems either lugging too hard or wound up too much. Hoping this will be the fix I need. The part # if you want it is, FUL K3538.
  4. Badkneesbear
    Badkneesbear Bobtail Member
  5. Badkneesbear
    I'm looking at a big cam 400 with a 9 speed transmission. The truck has 3.90 gears, can I put the box on the back to make a 13 speed and drop rpms for better speed and not running engine too high rpm? Any knowledge would be appreciated.:)
  6. barcaVnl
    barcaVnl Bobtail Member
    12
    5
    Feb 16, 2019
    I converted few years back. Around $500 for parts and labor at volvo dealer.
  7. lester
    2,919
    7,879
    Jan 2, 2012
    NW, Iowa
    Need to know what the model number of that trans. Some can be converted cheap and easy, others not so much
  8. trucker870sb
    trucker870sb Bobtail Member
    6
    I have a 2007 Volvo d12 @365hp runs 60mph at 1500rpm in 10th (last hole). 3.08 rears. Need to be able to run 70 comfortably. What’s best option? 13 speed swap ?
  9. bjytech
    bjytech Light Load Member
    238
    219
    Nov 9, 2013
    By the sounds of that you have just a direct 10 speed (no overdrive gear) so going a 13 speed transmission with overdrive will give you more speed at the same RPM,(all things the same this would be at 80mph in top OD @ 1500rpm and 70mph in lower OD @1500rpm) but with those 3.08 rears and 365hp pulling power is going to be a real struggle in overdrive with any weight.
