Can it be done? I've researched hard and haven't come up with anything yet. My trucks power supply to the reverse lights are only two wires and the new rear panel I bought came with led reverse lights that are 3 prong. Is there a way to hook my two wire setup (red & white) into the three prong pigtail? Or will I just have to go find a 2 prong styled reverse light? I've tried hooking it up in every different combination and no luck yet.
Thanks in advance and safe trails
2000 Volvo
Converting a 2 wire to 3 prong pig tail
Discussion in 'Trucks [ Eighteen Wheelers ]' started by HopeOverMope, Oct 16, 2016.
Not sure if this will help, but don't forget that led lights are polarity sensitive, meaning Ground has to be on ground, otherwise it won't light.
HopeOverMope Thanks this. -
just join the red and black wires together to power and the white to ground and it will work fine.
we did it like this for our long load lights all the time, if one element failed the other was there for back up.thejackal and HopeOverMope Thank this. -
Will try this in the a.m thanks... This wouldn't short anything out would it?
It shouldn't. Three prongs are normally for things like turn signals and break lights. The third prong will normally just intensify the light output. They can also be used on dual output lights (red and amber for example). The biggest thing is insuring you have ground to ground as mentioned before. And with LED lights ground is often White but can still be black. You should be able to get the lights to turn on with just two wires. But splicing the two hot wires into one will work also provided it just intensifies the light and doesn't change its color.HopeOverMope Thanks this.
