Converting a 2014 Volvo from a D13 to a VED12
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dirty Money, Oct 17, 2019.
  1. Dirty Money
    Dirty Money Bobtail Member
    7
    Is this possible? Has anyone done this?
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    I would say no it's not, and even if it were it would be so cost prohibitive it wouldn't be worth it. And I don't think you will find a shop that would risk the huge fines to install one.
  4. Dirty Money
    7
    Considering that gliders are built I would think the likelyhood of being fined for putting in frame is unlikely. The engine itself would comply with emmisions standards of its year. I would likely be doing the install myself with the help of some old mechanic buddies so that point might be moot. Appreciate your input though.
  5. Bad Monkey
    Bad Monkey Medium Load Member
    576
    367
    Jul 18, 2012
    Goshen, IN
    Except your truck is NOT a glider. They have different rules.
    lester and Socal Xpress Thank this.
  6. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    there is plenty of trucks on the road with the wrong year motor put it in and ride
    dustinbrock and rollin coal Thank this.
  7. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    Technically should be possible to install it but is illegal to use EPA 2004 motor on 2014 chassis, actually fist D12s came without EGR before 2004, ; would be more cost effective to sell it and buy a 2007 or older with D12 and don't have to worry every time you get pulled for DOT inspection.
  8. rollin coal
    rollin coal Road Train Member
    13,408
    27,263
    Mar 29, 2008
    TN
    The DOT does not care if anyone has a 2004 engine in a 2014 truck and they will never ask about it. Lots of trouble and expense to do this kind of swap though if not DIY. OP would be better off to get a 1999 or older truck in good shape already or just rebuild a tired one.
  9. AModelCat
    161,206
    All that work for what gain? Better engine options out there than the D12.
    Socal Xpress Thanks this.
  10. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    If you’re going to do a dumb swap put a n14 in it or anything pre emissions.
    the d12 and d13 won’t be a straight plug swap. Considering one is full of enissions and the other isn’t.
  11. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    if he already has the ved 12 and time what the heck swap it
