I talked to a to a mack tranny mechanic at the mack dealership and was told the 13 and 18 speed mack trannys are exactly the same, there is no difference in the gears. The only thing difference is the knobs. The 13 speed knob locks out the low side, the 18 speed knob lets you shift the low side. So if you have a 13 speed mack tranny, you can either buy a 18 speed knob and install it, and i think the cost of the knob is around 300 dollars, or take the the 13 speed knob apart, break off or cut out the lock out tang and you have yourself an 18 speed. So if your're ordering a new mack truck, order it with a 13 speed tranny, change or modify the shift knob yourself and you can save yourself the price between a 13 speed and an 18 speed transmission.![]()
converting a mack 13 speed to an 18 speed
Discussion in 'Mack Forum' started by gabbyjoe, Nov 26, 2011.
im guessing thats on the maxitorque 13's?
You,re right mack attack 2011. The maxitorque 13 speed is the one!!!
Do not try to do this with an Eaton! The gears are not the same in them and you will blow your transmission apart.
