Can a guy buy new hubs to convert an old axle from spoke to hub pilot?
I am buying a stainless tank and anything used is in the $30000 to $40000 range with hub pilot wheels.
these stainless tanks last forever, so id like to buy an older one and convert it when the tires wear out to save $ and hassel when working on it.
converting spoke to hub pilot
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mikec265, Oct 16, 2013.
You can swap over the entire used hub assembly. New is going to be pricey.
We changed over a few dump trucks. -
Thanks, ill check the bone yards
mikec265 Thanks this.
Well as long as i dont get a tank with propar axles i have hubs and wheel lined up cheap(scrap price). I might even buy a storage van for the parts and storage space. my 40x60 ft garage isnt big enough. I really would like to convert to anti lock brakes as well if i can.
I've never seen propar axles converted, they run odd bearings. I don't know if they can be, I have just never seen a hub for them for hub pilot wheels, but they may exist. Propars are easily identified by the clear plastic screw on hub caps. For ABS, you can get a Haldex retrofit system in the $400-500 range.
mikec265 Thanks this. -
From my understanding later fruehauf trailers used hub pilot hubs on propar axles.
