Coolant discolored and plastic resevour tank is darker
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by harlycharly55, Mar 9, 2021.
  1. harlycharly55
    harlycharly55 Medium Load Member
    608
    513
    May 5, 2014
    Houston, TX
    I have a 2018 Pete 579, Cummins X15 Performance with 313,000 miles and the coolant has turned a dark brown color, it's still clear but really dark, not using coolant, no coolant in the oil, did a head gasket test for exhaust gas in coolant and passed 2 times. What else can cause this? Thanks for any help!
  3. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    oil cooler can cause it also.
    harlycharly55 Thanks this.
  4. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    I change my extended life coolant at 300k. Sent coolant in for analysis. Even though the coolant says good for 600k
    Found mine was lacking in protection and coolant flush was recommended.
    Mine was also dark. I never go to recommended intervals anyway.
    May try sending a sample to a lab. My Local Cat dealer has a full service lab. They do testing for a variety of fluids
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,472
    6,509
    Aug 26, 2014
    Found one of our 388's had a transmission cooler above the bell housing. It was bad resulting in trans fluid in coolant and coolant in trans. Replaced it, flushed and refilled both. Replaced trans within 6 months.
  6. bowhunter67
    283
    549
    May 28, 2016
    rush city mn
    I had a tranny cooler go and mine didn't last 3 weeks after it filled with coolant that trans cooler got expensive really quick.
  7. harlycharly55
    608
    513
    May 5, 2014
    Houston, TX
    There isn't any oil in the coolant, coolant is still clear just dark brown color instead of red.
  8. bowhunter67
    283
    549
    May 28, 2016
    rush city mn
    Maybe a leaking egr cooler.
  9. Goodysnap
    Goodysnap Road Train Member
    3,718
    9,027
    Jul 12, 2017
    I agree get a sample and get it sent into the lab for analysis.
    I would also change it out immediately with new coolant and a filter.
    beastr123 Thanks this.
  10. harlycharly55
    608
    513
    May 5, 2014
    Houston, TX
    It's been checked twice for exhaust gas in the coolant system, passed twice.
