Coolant in fuel filters
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Sktrucker89, Feb 14, 2020.
  1. Sktrucker89
    Sktrucker89 Bobtail Member
    32
    Mar 9, 2016
    Hi i have a 2013 freightliner cascadia dd13. Coolant keeps coming into fuel filters and then prompting water in fuel codes. Changed the injector cups and o rings twice and happening again. What could be the next best reason that it is happening. Thanks in advance
  3. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    If it’s a heated filter I’d suspect that first after the work you’ve done.. try shutting off water supply to filter if you have a valve or bypass it temporarily to see if that’s the cause .
    Rideandrepair and AModelCat Thank this.
  4. 062
    062 Road Train Member
    6,233
    33,549
    Oct 20, 2013
  5. mhyn
    mhyn Road Train Member
    4,255
    4,514
    Dec 29, 2008
    Northridge, CA
    when you changed cups and o-rings did you remove remaining coolant from fuel tanks ?
    Rideandrepair, magoo68 and 062 Thank this.
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If the fuel caps are at end of tanks you can park with truck pointed to where water will pool up below fuel cap end of tank, a hose can be put to bottom of tank and most all water can be removed that way or look for allen screw at one end of tank to drain water out, if you have coolant heaters inside tanks look for leaks in them?
    mhyn, Rideandrepair and 062 Thank this.
  7. mhyn
    4,255
    4,514
    Dec 29, 2008
    Northridge, CA
    they are in the middle of tanks...
    Rideandrepair Thanks this.
  8. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    You can buy a hose called a magic hose at T/stop with a ball in the end to start it to pull water out of bottom tanks ?
