coolant leak after coolant pump replacement
Discussion in 'Volvo Forum' started by FAP, Dec 15, 2013.
  1. FAP
    FAP Light Load Member
    81
    13
    Oct 14, 2011
    Chicago, IL
    hey guys,
    I just realised I have a few drops of coolant under the coolant pump... pump itself was replaced 2 weeks ago with a new pump and sealed nicely by my mechanic in chi. also, coolant level is down a little... what might be the problem...
  3. Wings2Wheels
    Wings2Wheels Medium Load Member
    301
    324
    May 3, 2008
    Eastern PA
    What kind of tractor, what kind of motor? Be specific.
    I guess you're referring to the water pump. First thing I would think is gasket didn't seat, or is torn or defective. Do you see any puddles under the truck after its shut down?
    How much antifreeze is it using over a course of days/miles?
  4. FAP
    81
    13
    Oct 14, 2011
    Chicago, IL
    05 Volvo d12,
    my bad, sorry. it lost about 1/2 a gallon so far maybe even less
  5. FAP
    81
    13
    Oct 14, 2011
    Chicago, IL
    1/2 gallon in 2 weeks let's say. I saw it dripping really slow tonight while idling
  6. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    Many times the hoses and clamps are reused that connect to the water pump to keep costs down. Once coolant hoses have been in service for a while they harden up. Once they are removed, and then reinstalled, they will never seal 100%. You probably have a hose or o-ring that was reused. A simple loose clamp could be the issue as well.
    FAP Thanks this.
  7. Wings2Wheels
    301
    324
    May 3, 2008
    Eastern PA
    No worries...just trying to help us help you.
    If it is weeping from the pump, and you don't have coolant leaking from anywhere else, and your oil isn't milky looking...I would suspect the gasket at the pump.
  8. Wings2Wheels
    301
    324
    May 3, 2008
    Eastern PA
    The above is absolutely true as well...I would run it with the hood open and see if you can spot where it's weeping from.
  9. FAP
    81
    13
    Oct 14, 2011
    Chicago, IL
    hm, good pointing guys. I'll wait for daylight and then do an inspection to see what's the issue
  10. FAP
    81
    13
    Oct 14, 2011
    Chicago, IL
    well, it is leaking through a weep hole but seems like less and less every day. my other concern is mixed oil with coolant. guy who changed pump changed oil at the same time but he added too much oil. I guess extra oil has to find It's way out somehow?
  11. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
