Coolant leak but can't find where is from?
Discussion in 'Freightliner Forum' started by nsxftw, Oct 28, 2014.
  1. nsxftw
    nsxftw Light Load Member
    192
    39
    Dec 2, 2011
    n/a
    I have 07 century w detroit 60series. I thought leak was from coolant reservoir so I replaced brand new reservoir tank but after drove 500 miles the level dropped from Max and about 2inch. I check all the coolant lines on the engine and have not spotted any leak. Is there any other lines that deal w coolant?
  3. Old Man
    Old Man Road Train Member
    4,597
    13,469
    Apr 3, 2009
    Oklahoma City, OK
    Maybe head gasket or pitted liner.
  4. nsxftw
    192
    39
    Dec 2, 2011
    n/a
    I also would like to say when I got rid of old coolant reservoir there was some oil in it which make the tank looks dark.
  5. nsxftw
    192
    39
    Dec 2, 2011
    n/a
    What's the pitted liner if u don't mind?
  6. bad-luck
    bad-luck Road Train Member
    3,282
    6,036
    Nov 16, 2013
    Baltimore, Maryland
    there could be several reasons for this. At first I was going to suggest that the cause was an EGR cooler and tell you how to diagnose that problem. But now that you said you're coolant is dark I am leaning towards an injector cup. Detroit series 60 s are known for the injector cups leaking.if its an injector cup it's actually diesel fuel getting into your coolant not oil
  7. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    Have you ruled out the bunk heater? When you park it overnight, is there a puddle under the right rear corner of the bunk?
    Also, how full are you filling the reservoir initially? Mine will spit out anything 1/4" above the "Cold Min" line almost immediately and then stay there for months on end until the small leak in the bunk heater finally causes me to add just a little.
  8. nsxftw
    192
    39
    Dec 2, 2011
    n/a
    i don't have bunk heater in my truck. Also I should've flush all the coolant out when I bought the truck two month ago. It was already dark and i thought it was when old coolant reservoir was old/dirt
    Should I clean the coolant out then? Would it be head gasket if oil could be go through coolant?
  9. iraqralph43
    iraqralph43 Road Train Member
    1,703
    2,796
    Jan 9, 2012
    If the truck has an EGR cooler...thats what Im thinking
    Rideandrepair Thanks this.
  10. nsxftw
    192
    39
    Dec 2, 2011
    n/a
    Yes. I do have a EGR cooler.
  11. nsxftw
    192
    39
    Dec 2, 2011
    n/a
    i post on one of the thread, i had exactly same problem with that other guy that there is water dripping from passenger between air filter/firewall. It could be ac after i used right? I remember before i bought the truck, they have bypassed the heater line for the bunk so they put the line back in so i can used heater on the bunk. i wonder if that caused the problem for heater core?
