Coolant leak from the radiator cap
Discussion in 'Freightliner Forum' started by Eska, Jul 22, 2017.
  1. Eska
    Eska Light Load Member
    165
    154
    Dec 21, 2015
    I have a Freightliner cascadia with cummins cm2250. My problem is, coolant leaking from the radiator cap, i changed the cap with the new one and new one is leaking too. My engine is running 15-20 degrees hotter than usual and when it gets hot oil pressure drops. I dont know if it has anything to do with the last repairs but i changed the oil pan seal, crankcase breather filter. And right after this it started to having these problems. Any ideas or similar experience?
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Did you clean the rad. very well where the rad. cap seals inside the top of rad.?
  4. Eska
    165
    154
    Dec 21, 2015
    I dont know if we are talking about the same thing. Im talking about the coolant reservoir cap. Is it the same thing?
  5. Eska
    165
    154
    Dec 21, 2015
    Also i dont think it has anything to do with cleaning. I believe the pressure is greater than the cap capacity. I need to find the source of the pressure build up.
  6. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
    Overfilling with coolant?
  7. Ridgeline
    22,124
    113,381
    did you bleed the coolant system?
    also check the overflow container where the cap goes.
  8. Kenworth 4life
    Kenworth 4life Medium Load Member
    423
    6,711
    Feb 16, 2017
    Augusta, Maine
    Poke a hole in the bottom and it won't leak out of the top! It could be over pressuring from a bad head gasket
    Klleetrucking Thanks this.
  9. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Start with a cooling system pressure test.
  10. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    Make sure you aren't filling expansion tank above the MAX line when cold. Coolant expands when it gets hot and if there's no expansion room it will spit coolant past the cap.
    If you're good with the coolant level next step would be the pressure test as recommended above.
    Frank
  11. baha
    4,137
    2,835
    Jul 25, 2013
    ga
    The build up of old coolant under where the cap is trying to seal on top of rad is where you need to clean so the new cap can seal, be sure you did not buy a china made copy of a real cap? if a china made was found go buy a real cap!
