It looks like coolant is traveling through some thick plastic tubes. Do these things have some sort of rubber seals? Has anyone encountered this before? Images below. I have a 2014 Freightliner Cascadia.
Coolant Leak Under Glovebox?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Dec 17, 2018.
Heater Core-
stillwurkin, mslashbar and PE_T Thank this. -
Look like corrosion from condensation. I don’t see actual leak Have you seen actual antifreeze?
PE_T Thanks this. -
Rideandrepair Thanks this.
I wonder what in the world would cause a 5 year old truck to have a bad heater core
Super_Trucker and HotH2o Thank this.
700K miles in 5 years means 140K miles/year. That's a fair amount and stress on the truck. A bad heater core is definitely plausible. I'd replace the heater core if for nothing else, preventative maintenance. It could be clogged, etc.
Wish you luck!PE_T Thanks this. -
