Coolant leak upper radiator hose
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by D.Tibbitt, May 17, 2019.
  1. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    I think it is too tight. FL has anal specs for torque ratings on anything under the sun/hood.
    I remember the upper coolant hose leaking once, went to tighten it and it wasn't even "tight", more like just barely enough to get the job done. It felt like I could just yank on the end of the hose and pull it right off the radiator without much effort.
    might need a new hose... :( And take it easy, 14-20 foot pounds? probably 12 :tard: just a guess...
    Rideandrepair and D.Tibbitt Thank this.
  3. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Glad you found out the radiator is bad.
    But also you will be needing a new reservoir as the old bottle once bad protocol is just to change the radiator.
    Modern engineering is goofy.
  4. Dave_in_AZ
    414,412
    We need an update.
    D.Tibbitt and Rideandrepair Thank this.
  5. truckermanotr
    truckermanotr Bobtail Member
    4
    Nov 13, 2019
    Nothing wrong with a Cascadia with DD engine... Got 550,000 on my 14 only thing I had to replace is the starter and radiator... It works hard on lease roads in the oil field all day..
  6. Rideandrepair
    17,448
    56,615
    Aug 8, 2015
    I’ll give an update on the SS constant pressure clamps, just had one snap, Broke right in the middle of the band. Lower hose at water pump. Never saw that before, been on there 4 + yrs.
    D.Tibbitt Thanks this.
  7. truckermanotr
    4
    Nov 13, 2019
    Probably made in China
  8. Restless28
    Restless28 Bobtail Member
    May 21, 2020
  9. Restless28
    May 21, 2020
    I'm having same problem. So what did u do about leak
  10. D.Tibbitt
    153,265
    New radiator
