Coolant leak
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kraiz1, Apr 22, 2021.
  1. Kraiz1
    Kraiz1 Bobtail Member
    I have a coolant Leak that is leaking from the center of the driver side block area on a Detroit motor 2016 Cascadia looking for answers. Check the head do not see it leaking from the top side OR THE HEAD. cannot see where is leaking slowly only leaks certain times
    Trucking Jobs in 30 seconds
  3. SophiaWYO
    SophiaWYO Bobtail Member
    36
    55
    Nov 22, 2020
    Wyoming
    Dry your engine off completely. Go to the dollar store and buy 2 containers of baby powder. Spray the powder all over your engine then start it up and look for the leak, it will be visible in the powder. If you still can't find it the dealership has an ultraviolet solution they can add to your coolant then check it with a black light.
    Hope this helps.
    Sophia
    BoxCarKidd Thanks this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    3,289
    4,517
    Aug 26, 2014
    Interesting. That's new to me.
    spsauerland Thanks this.
  5. me myself and I
    me myself and I Medium Load Member
    651
    262
    Oct 5, 2009
    vernon hills,Il
    Coolant lines going to compressor. Known problem
    Smellfunny Thanks this.
  6. Dairon00
    Dairon00 Bobtail Member
    8
  • Draft saved Draft deleted
