ok after pistons and head gasket seal and rocker arms, head adjustment a good amount of other stuff. i have a huge leak on my passenger side. TA did pressure test and found 2 clamps leaking. replaced both. next day same issue. my shop ay my company went through it with me. same clamp he replaced at TA. so we replaced hose. i drove it 20 min after truck engine wash with no sign of leak. but im not convinced. can it be from my shop not closing head right? ive had 3 or 4 ppl 3 mechanics look. and no one can tell. imma attach pics which prob wont help. but maybe itll ring a bell if u seen it before. im losing my mind and its killing me. im thinking detroit diesel can check this. just fyi egr has been blocked for a over a year.
coolant leak
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 4noReason, May 23, 2018.
Page 1 of 4
the hose i changed was the one on passenger side top big hose.
Typical TA parts changers. Hoses often start leaking under a clamp so just changing the clamp wouldn't have made any difference. You should be ok now. Just keep an eye on it.
4noReason Thanks this. -
@4noReason you don't see from where is coming out coolant?
Page 1 of 4
