coolant level
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bob1234, May 27, 2013.
  1. bob1234
    bob1234 Light Load Member
    71
    Nov 10, 2010
    brantford, ont
    I have a question with coolant level on a 06 Pete 379 c 15 acert with a metal expansion tank mounted on the firewall the the one with the sight glass in the side when the engine stone cold should u see coolant in the sight glass or until its wormend up coolant should be visible in the sight glass.
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Fill it up cold to just cover the sight glass. It doesn't make much sense for a company to want you to add coolant to hot engine and risk burning their customers :). Most of the time after a few years, the sight glass become useless anyway. If you look down the filler neck, it extends into the reservoir. The proper level is about 1" below the the tube. If you fill it up to the tube or more, it'll push some out when it heats up.
  4. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    If the sight glass gets dirty it can be removed and cleaned, they are available at any truck dealer. I use an 8 point socket to remove and replace them. Use gear oil on the threads and 'O" ring, very gently.
    GrapeApe Thanks this.
  5. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    I never even thought to try, but I will now. Not worth it to drain coolant out just to change it, but if it has to be drained for another reason, it'd be a good time to clean or replace. Thanks,
  6. JohnP3
    1,594
    683
    Feb 21, 2010
    When the engine is cold you screw one out and the new one in, you loose maybe a couple of Ounces at most. 99% 0f the cooling systems that have dirty sight glasses use DCA4. A coating not a cooling system protectant.
