Coolant missing
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Khaled, Jun 27, 2018.
  1. Khaled
    Khaled Bobtail Member
    Good morning everyone i been having coolant missing in the Past 2 weeks
    there’s no leaks at all in the hoses someone told it could be the egr cooler so i went yesterday to mechanic shop he checked the egr cooler but it was fine and he checked everything that he can see still everything is fine
    So he end-up telling me it could the fuel injector cap or a head gasket!!
    ^^So my Q is do the fuel injector cap can cause coolant missing ?!
    Did any one had this problem before
  3. Ridgeline
    22,672
    121,406
    Well let's start with filling us in of what engine and truck it is.
    Heavyd and AModelCat Thank this.
  4. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    First thing to do is a pressure test. It may show where your leak is. If it's a head gasket your oil will be milky.
  5. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    Can you see exhaust coming out your stack? What color is it? Could be mixing in the combustion process and blowing out your exit.
  6. Jonrulerofearth
    Jonrulerofearth Light Load Member
    232
    340
    Sep 1, 2011
    Hueytown, Al
    Could be magic, possibly.....
    Oldironfan and Heavyd Thank this.
  7. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    Yup, pressure test with the oil pan off will show if it’s getting past the head. Or maybe it is a hose that only leaks under high pressure, which a pressure should show you.
  8. truckdriver31
    6,998
    8,362
    Sep 18, 2013
    there are two leaks. cold and hot. you have to break it down.
  9. skinnytrucker79
    skinnytrucker79 Light Load Member
    142
    1,601
    Jul 21, 2013
    Wisconsin
    I had a similar issue in a T660 with the Cummins . About every other week I would have to top it off to trip the low coolant sensor , we did a leak down test without any signs of leaking out , it had to be going through the engine but it didn’t matter since at 750,000 miles it tossed a rod bolt through the side of the block
    Oldironfan Thanks this.
  10. Heavyd
    Heavyd Road Train Member
    7,821
    6,273
    Feb 4, 2009
    It's still the egr cooler.
  11. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    Good ole isx window block. It stays cooler from the fresh air.
    skinnytrucker79 Thanks this.
