Coolant pressure buildup
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Andy1982, May 16, 2021.
  1. Andy1982
    Andy1982 Bobtail Member
    6
    May 16, 2021
    HI,
    My coolant is overflowing from the coolant tank, looks like hot air is blowing to the tank, when the coolant temperature is between 180 and 190, still have spitting coolant.
    I have changed my coolant tank and the thermostat and even radiator but still having the same issue. What would be the issue come from? is it from the bad air compressor or cylinder head
  3. BigBob410
    BigBob410 Road Train Member
    5,664
    74,096
    Feb 2, 2016
    Beirut on the Bay, MD.
    I’m no truck mechanic...but it sounds like you need one. Could be a head gasket issue, a liner issue a head issue. There are tons of spots that compression could be getting into your cooling system. What engine are you working on?
  4. Socal Xpress
    1,855
    1,957
    Dec 6, 2014
    Los Angeles, Ca
    Well it would be helpful to know what year make model engine. Just a thought.
    AModelCat Thanks this.
  5. Andy1982
    6
    May 16, 2021
    I'm working on 2012 volvo d13 I have check the engine oil even tested it for water in engine oil that looked OK
  6. Andy1982
    6
    May 16, 2021
  7. Socal Xpress
    1,855
    1,957
    Dec 6, 2014
    Los Angeles, Ca
    Ok I would test the coolant to see if combustion is mixing with it.
    Check the EGR cooler and the air compressor. Injector cups could also cause the cooling system to over pressurize.
    Good luck
  8. AModelCat
    145,367
    If you're floundering and replacing big dollar parts on a hunch, I would suggest simply taking it to someone who knows how to diagnose. Its cheaper than throwing parts at it for no reason.
