Coolant surge tanks, anyone know?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 55_cans, Oct 6, 2012.
  1. 55_cans
    55_cans Light Load Member
    98
    19
    Sep 14, 2012
    Alberta
    My Scania engines have a plastic surge tank as a coolant reservoir, but the darn things don't last, they break and disintegrate, the plastic breaks down. My freightliner FLD120 has a metal surge tank over the rad and I'm thinking about buying some and adapting them to the scania setup. Before I do, I was wondering what else might be available.
    The freightliner tank is as long as the rad, about 3-4" thick and 8-10" wide (going by memory). Was wondering if any other manufacturers tanks KW, Western Star, Etc. would be available in metal and 1/2 as long as a typical Rad and maybe 8-10" deep and 8-10" wide. If it held about 10-15L that would be good.
    PS, the surge tank is pressurized, I think about 9lbs (my memory again :)).
  3. dodge24v
    dodge24v Light Load Member
    99
    34
    Nov 21, 2010
    VA
    I got a plastic one on my cascadia. 1.5yrs old with 210,000 miles on it. still looks brand new
  4. 55_cans
    98
    19
    Sep 14, 2012
    Alberta
    Duplicate post
  5. 55_cans
    98
    19
    Sep 14, 2012
    Alberta
    Thanks for the reply.
    I think mine break because I'm mostly off road, vibration is high and temp low -20C to -40C.
    What's the rough size of the tank on yours (guess is good enough). I'll try and search it and see how the plastic casting compares to the Scania.
  6. alaga
    alaga Light Load Member
    195
    62
    Jan 9, 2012
    Fayetteville, GA
    First plastic tank on my '03 Mack started to leak and was replaced, but the 2nd one has held up for quite a while. Looks like one circular piece but it is actually 2 tanks (2 half-circles mounted together); the pressure cap is on the top tank.
    Don't know if that helps...nice that FL stuff holds up so well.
    Durn cold where you operate, too; my tank would leak thereas well!
  7. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    The filler neck, you can buy, and a decent tin smith can fabricate one up for you out of brass, I do not know how galvanised steel would hold up, in the cooling system.
    The shop would need the old tank, as a pattern.
    All things are possible
    55_cans Thanks this.
  8. 55_cans
    98
    19
    Sep 14, 2012
    Alberta
    What's the rough size of your Mack tank?
  9. 55_cans
    98
    19
    Sep 14, 2012
    Alberta
    Yep, if it comes to that I'll try and use the mig and make one out of aluminum. But I thought I'd try a ready made metal one first if I can find one.
  10. VisionLogistics
    VisionLogistics Road Train Member
    1,551
    978
    Dec 8, 2011
    Jellystone
    Check into a used one from a T2000 KW. Metal, and about half as long as what you describe.
  11. alaga
    195
    62
    Jan 9, 2012
    Fayetteville, GA
    Not around my truck now, prob be a couple of days bedfore I can get measurements or maybe a pic (if I'm smart enough to get that on here!). But I will guess 15" across and 5" deep. They have had a rep for not being the most reliable, at least the ones from a few years back.
    Prob should have mentioned this is remote-mounted on the firewall, not on/at the radiator.
