Coolers and battery life
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by freebirdusa, Jul 24, 2016.
  1. freebirdusa
    freebirdusa Light Load Member
    271
    133
    Oct 21, 2014
    Thomaston ga
    I have a Koolatron 40or 44 quart electric cooler. Not positive but I believe that its a 44 quart. Im not at the truck right now so I cant confirm that. My question is can I leave it plugged in overnight (10-12 hours) with the engine off without depleting my batteries low enough to not be able to crank the truck. I drive a 2013 KW T660 with no apu or switch to turn on that cranks the truck if the batteries get too low. Just thought I would mention what equipment I have incase anyone was curious what Im working with here. Im also wondering if this heat wave we are having could have an effect on the battery performance. Im in Georgia and its been getting up to 95% here everyday. Any dvice would be appreciated.
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    It will knock down the batt. over a long wk. end but not over/night, a half bag of ice inside ziplock bag with it unplugged will keep food good in my same cooler if its out of sun and not sitting on hot floor of truck?
    shortcut and rabbiporkchop Thank this.
  4. bzinger
    bzinger Road Train Member
    16,613
    65,927
    Dec 10, 2014
    omaha , ne
    As long as you have decent batteries 12 hrs won't be a problem.
  5. freebirdusa
    271
    133
    Oct 21, 2014
    Thomaston ga
    Thanks for the replies
  6. reefer75
    reefer75 Medium Load Member
    320
    102
    Feb 26, 2011
    midwest
    should have a battery protection on the truck i know mine does.Will cut the power when gets below cranking amps something like that. check your owners manual then the truck
    freebirdusa Thanks this.
  7. snowwy
    snowwy Road Train Member
    20,545
    13,280
    Jul 6, 2009
    I think every truck has a low voltage shut down these days. You're electrical circuit will shut down before the truck won't start.
    reefer75 Thanks this.
  8. freebirdusa
    271
    133
    Oct 21, 2014
    Thomaston ga
    I wonder if it will shut down if I have the cooler wired straight to battery box. BTW it fired up after sitting aroun 14 hours. Votage was 13
  9. snowwy
    20,545
    13,280
    Jul 6, 2009
    If you're reading 13 volts after 14 hours. I'd be having them batteries looked at.
    Full charge is 12.6 volts. A brand new battery in good condition will read 12.7 volts after stabilizing on engine shutdown.
    Batteries that read 13 volts and stay there. Aren't soaking in the full charge from top to bottom. And to read that after 14 hours. With fridge useage.
  10. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Probably read them with a voltmeter which will read higher. He needs the meter that will add a load to give a more stable reading.
