Cooling fan C12 cat cuts in and out all the time when driving
Discussion in 'Canadian Truckers Forum' started by Blakden, Mar 29, 2019.
  1. Blakden
    Blakden Bobtail Member
    Has anyone had a problem with cooling fan kicking in and out all the time. Engine temp doesn’t get above 150. It’s in a FL115 tuck
  3. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Sounds like a thermostat problem.
  4. Expeditor
    Expeditor Medium Load Member
    451
    530
    Mar 5, 2018
    Could be bad high pressure A/C switch. The weather is not hot enough to cause fan to come on from A/C, so a bad switch can cause the fan to come on.
    Cam Roberts and IH Truck Guy Thank this.
  5. stayinback
    stayinback Road Train Member
    3,911
    8,256
    Jan 24, 2014
    chicago,il
    Yeah I did- How did I fix it?
    I did 3 things and not sure which 1 fixed it,But it worked.....
    1.Remove both ECM plugs,Clean them use contact cleaner,Check for broken wires then reinstall.
    2. You'll have a Black Air line going to the Fan Hub- Pull it off-Blow air in the Hub,Clip the Line for a Clean install,Then tap the hub a few times with a rubber hammer.
    3.coolant temp sensor- Unplug,Clean connector and pins in the sensor-Reinstall.
    I did those 3 things..And It Never came on again unless Im Pulling Big Hills.
