I have a 98 fld 120 with detroit 60 series motor. I notice I been loosing antifreeze (leaks) from the overflow hose off the radiator cap. when engine running I can see small drops leaking and have to add antifreeze about every five days about 1 gallon. engine temps look in the normal range and oil pressure also en the normal range when running. truck operates good, just have that issue about loosing the antifreeze.
anyone have any suggestions on what my problem can be? I have heard from bad head gasket to bad heater valve in the bunk that can also cause compression in the cooling system.
Just wanted to hear from the more experience guys on what this problem could be.
I appreciate any help in advance.
thanks
tony
cooling system problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tonher, Dec 3, 2015.
Page 1 of 3
My best guess is head gasket. I've seen that cause a geyser with the radiator cap off
Could the cap be faulty?
No a bad cap wouldn't allow the pressure to build
I've had a cap on a c10 cause the overflow to drip
Please suspect your head gasket last. The rad cap itself is may be faulty and simply cannot hold any pressure, that is the cheapest fix. Second, I would suspect the air valve for the heater, then the air compressor and finally a head gasket. You can pinch off the air supply to the heater valve, or leave your air tanks open and run the engine to see if the problem continues. If you have combustion getting into the coolant, pressure usually does not build up until the engine is hot. To test the air compressor, just disconnect the compressor outlet line and run the engine.
tonher, QUALITYTRUCK, SAR and 3 others Thank this. -
thank you for your information sir.
I changed the radiator cap and problem still there. Trying to locate the air valve heater. I have a 2000 fld120.
Do you know where this valve is located? is this valve electric or air operated?
thanks again for your help.
tony -
My brain is failing me right now. It has been many years since I changed one, but they are air operated and when they leak air the compressed air leaks into the coolant to cause issues like this.
The valve is under the bunk on the passenger side. It's right by the heater core. Just flip up you mattress and you'll find it, it's the only airline going to the HVAC box.
Heavyd Thanks this. -
Get a water bottle that your overflow tube will fit in,you need a couple inches of water in bottle. Start truck,put tube in the bottle so the end is underwater. If you see bubbles,take the line off top of compressor,see if they go away. That will narrow it down some.
Page 1 of 3
