coranado hood swap?
Discussion in 'Freightliner Forum' started by Pro1968, Mar 30, 2015.
  1. Pro1968
    Pro1968 Bobtail Member
    Looking for some answers to whether I can swap my '04 hood for one of the newer SD versions, they appear to be similar dimensions, but are the mounts the same or at least close enough for some minor fabrication? Any advice would be appreciated.
  3. BigJls1
    BigJls1 Medium Load Member
    482
    415
    Dec 25, 2012
    it might fit but what about the front axle. the axle on the SD is like 8 to 10" set back. you moving the axle on yours?
  4. Pro1968
    yeah I saw that on the day-cabs, but recently I've seen full condo versions and was hoping it might be different, because moving the Hendrickson air glide front suspension might be too much of a problem.
  5. KVB
    KVB Heavy Load Member
    877
    2,875
    Jun 30, 2012
    The old style Coronado was a long hood, 132 bbc.
    New coronado is available as short 122 and long 132 bbc set forward axle, and SD 122 set back axle.
    Not sure if it will fit without any modifications, but the long hood set forward would be my best bet
    A friend put the old style coronado hood on a Columbia. Extended the frame, moved axle forward, etc. Big job, and it's still a Freightliner
