Coronado 2017 Glider issue warm air
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by simpletruckerr, Nov 1, 2020.
  1. simpletruckerr
    simpletruckerr Bobtail Member
    5
    Hi, can anyone help plzz
    2017 Glider Coronado getting warm air
    1. New heater cores front n back
    2. Coolant lines are hot under the hood
  3. simpletruckerr
    5
    Plz help. I took 3 times to mechanic. Still no luck
  4. lester
    2,934
    7,939
    Jan 2, 2012
    NW, Iowa
    I don't understand your issue? Air not hot enough or not blowing cold
    spsauerland and magoo68 Thank this.
  5. simpletruckerr
    5
    Air blowing warm air not hot enough.
    A/C working fine blowing cold.
    But heat is not enough hot. Just warm
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    Had a Western Star. Found the temperature control cable was mounted too far up on the lever for the valve. Caused the temperature valve to only open partially.
    I mounted the cable in a hole closer to the valve stem, giving it more travel. lots of heat after that.
    AModelCat and simpletruckerr Thank this.
  7. ZVar
    ZVar Road Train Member
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    Is there a valve to shut the heater core off? Has been on several trucks I've driven....
    Love for a water spigot like valve and open it up...
    simpletruckerr Thanks this.
  8. lester
    2,934
    7,939
    Jan 2, 2012
    NW, Iowa
    Assume engine water temp is running warm enough as well. I like the other guys theory of water temp control valve not opening fully. But hard to believe 3 shops couldn't figure it out
  9. simpletruckerr
    5
    Should i take the truck to Freightliner dealer? Cause all other mechanics rejecting to look at this problem, saying too much time. Or can i do it myself? Would be really good if someone explains where is what? So i could look it up by myself. (Btw i am not that profi, i m new with this glider)
  10. simpletruckerr
    5
    2 days ago changed thermostat, still no luck. Only warm air.
  11. lester
    2,934
    7,939
    Jan 2, 2012
    NW, Iowa
    Gotta be a blend door or a blend valve of some sort.
    simpletruckerr and Roberts450 Thank this.
