Cost for C15 Gold Inframe?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ahmadali04, Feb 3, 2012.
  1. ahmadali04
    ahmadali04 Bobtail Member
    28
    6
    Jan 30, 2011
    Hi. I have a 07 Pete 379, and looks it I am going to be needing to do an Inframe on my CAT C15. Does anyone know, how much it will cost me, if I were to go with the "Gold" kit from CAT? (How much are parts and labor?) Thanks.
  3. Tank33
    Tank33 Medium Load Member
    346
    108
    Jan 10, 2009
    British Columbia
    Don't take this to the bank, I am just guessing here, but if CAT did the work, or any other large shop, I would plan for $30,000.
    If the truck is a 2007 your probably still on your original radiator, clutch, air compressor, a lot of your major components are factory original most likely. While your doing an in-frame, I would replace the clutch, have the transmission opened up and checked, check the input shaft very closely, if you have any vibration at all, replace it.
    Replace any and all fuel, oil, coolant lines that are easy to get to with the truck torn down. I would do a new transmission cooler too.
    This is not the time to skimp, replace everything if you haven't in a long time, including the radiator, fan hub, you name it.
    Why are you needing an in-frame so soon? The CAT engines that are pre-2008 are racking up a lot of miles with no problems. My old 2004 C15 has 1,600,000 KM (994,000 miles roughly) on it now, no oil usage, great fuel economy, and no problems at all.
    Truemac Thanks this.
  4. rollin coal
    rollin coal Road Train Member
    13,101
    25,967
    Mar 29, 2008
    TN
    I know someone who had a platinum overhaul that cost $19k and some change out the door. 9.75% of that cost was TN sales tax, if you can have this work done in a state without sales tax on it go for it.
    Tjackson4 Thanks this.
  5. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    No need to replace all those things especially on a 4 yo truck ....do a inframe cylinder packs, rods, mains, check liner protrusion , a reman head and go on down the road for $10 -12,000 .....replacing good , serviceable expensive components is just wasting money .
  6. gonzo01
    gonzo01 Light Load Member
    74
    5
    Jun 14, 2010
    denver, co
    A CAT platium inframe kit cost $11500.00 alone...
    How so cheap??
  7. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    My '06 C15 Acert was done by an independent shop using the gold kit and the kit it's self was $5,568.93 part# 10R9923. Total cost of the inframe including a reman head $11,961.46. $2400.00 of that was labor.
    I agree though the platinum kit comes with stuff you probably don't need.
  8. wrenchead
    wrenchead Bobtail Member
    37
    5
    Dec 6, 2008
    ELK RIVER,MN
    cost was 3920.16
  9. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    an inframe on a truck that's 5 years old with ?????? 600K miles?
    Thought an inframe wouldn't be needed till 900-1,000,000 miles.
    I can see a lower (bearings only) being done to it.
  10. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    Normally I would agree but mine had a cracked liner flange on #5 and 4&6 were questionable so I just did them all.
  11. MNdriver
    7,985
    4,371
    Feb 24, 2012
    ok....
    So umm...
    What caused pre-mature cracked liners?
