Cost of swapping a 10 to a 13 speed.
Discussion in 'Freightliner Forum' started by LoneRanger, Jun 14, 2018.
  1. LoneRanger
    LoneRanger Road Train Member
    3,687
    9,584
    Jun 3, 2018
    I would think the rear ends would need to be changed out, but what else might be involved in switching out a 10 speed on a cascadia to a 13 speed.
  3. spyder7723
    spyder7723 Road Train Member
    15,471
    25,076
    Mar 31, 2013
    sarasota, fl
    Why would the rears need changed out?
    The only thing you will need to do is shorten the driveshaft and have the ecm reprogrammed to match the transmission.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    True that. Generally a ten and thirteen speed has the exact same final ratios.
    They can be different, so you would have to confirm the model numbers.
  5. mslashbar
    mslashbar Medium Load Member
    601
    808
    Jul 22, 2009
    elizabeth,co
    It probably won't be cheap. They probably won't accept your 10 speed as a core for the 13 speed.
    Justrucking2 Thanks this.
  6. LoneRanger
    3,687
    9,584
    Jun 3, 2018
    Did not know a core is needed to make the switch.
    I was thinking of more like selling old one.
  7. mslashbar
    601
    808
    Jul 22, 2009
    elizabeth,co
    You can convert a 9 speed to a 13 speed but not a 10. To convert a 10 to a 13 requires a whole new transmission. They will charge a core charge when you purchase the 13.
  8. spyder7723
    15,471
    25,076
    Mar 31, 2013
    sarasota, fl
    They are actually off by .01 but that's such a small amount you wouldn't even notice it in your speedometer.
    uncleal13 Thanks this.
  9. spyder7723
    15,471
    25,076
    Mar 31, 2013
    sarasota, fl
    If you go to a small independent shop they will likely accept your good 10 as a core for a rebuilt 13. On my last truck i got quoted 2500
    installed with my 10 as a core. That price was just the labor and transmission, did not include the machine ship costs for shortening the drive shaft or the part costs for a new clutch.
    LoneRanger Thanks this.
  10. LoneRanger
    3,687
    9,584
    Jun 3, 2018
    $2500 is reasonable I think with a core, but then again I’m new.
    Did it come with a warranty on the rebuilt 13?
  11. J.S.
    J.S. Medium Load Member
    472
    209
    Jun 27, 2015
    Texas
